Giuseqpe Posted July 10, 2014 Report Posted July 10, 2014 I have a XS power d3400, 2 xs power d3100 and a Singer alternator 240amp on the way. The amps is a DD M3b and a RF T1000.4. Do I have enough to run it full tilt for some time? I never compete or anything, just for daily bumping. I have done Big 3 in my car already (1999 VW passat) and I have one run to the back, all 1/0gauge. Is it necessary to have 2 runs from alt to front batt, or 2 runs positive to the back or a negative front to back? In the future I plan on adding 2 more subs (aq hdc312) and one more M3b, how much more would I need then? Is it possible to remove AC and put another alt there? Only way I can fit another one Some input would be great, Thanks
evermaxx Posted July 10, 2014 Report Posted July 10, 2014 You should be fine, id pick up another 3100 though. And can't tell you about adding another alt. Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench
Jhunt94 Posted July 11, 2014 Report Posted July 11, 2014 I have a XS power d3400, 2 xs power d3100 and a Singer alternator 240amp on the way. The amps is a DD M3b and a RF T1000.4. Do I have enough to run it full tilt for some time? I never compete or anything, just for daily bumping. I have done Big 3 in my car already (1999 VW passat) and I have one run to the back, all 1/0gauge. Is it necessary to have 2 runs from alt to front batt, or 2 runs positive to the back or a negative front to back? In the future I plan on adding 2 more subs (aq hdc312) and one more M3b, how much more would I need then? Is it possible to remove AC and put another alt there? Only way I can fit another one Some input would be great, Thanks Another battery wouldn't hurt and 1 run from alt to front batt and 2 runs of positive from front to back. Some people run the negative from front to back and some don't so I'm not sure what to tell you on that. 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter
n8ball2013 Posted July 11, 2014 Report Posted July 11, 2014 My theory iw if you are at thw point where you think you might be ok but arent sure you add another THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Giuseqpe Posted July 11, 2014 Author Report Posted July 11, 2014 Yeah still waiting on some stuff before I throw it all in I'll see how it does then and add another if its needed. Thanks
