ace_ventura Posted July 12, 2014 Report Posted July 12, 2014 hy guys my name is anthony and i live in belgium. i have 2 alpine SWR-1021d subs with an alpine mrd-m500 amp i would be very glad if someone could help me out with a good box design for these subs :-) because i have no clue on how to do it lol :-) here is a link to a pdf sheet http://vault.alpine-usa.com/products/documents/OM_SWR-1241D.PDF thx
harlemn8ive Posted July 12, 2014 Report Posted July 12, 2014 First and foremost what are the dimensions of ur trunk Check out my build slow but... slow and steady wins the race http://www.stevemeadedesigns.com/board/topic/185561-1st-build-budget-toyota-mark-2/
ace_ventura Posted July 12, 2014 Author Report Posted July 12, 2014 2010 ford focus turnier facelift The dimensions are 45cm high. 110cm with and 80cm depth
harlemn8ive Posted July 12, 2014 Report Posted July 12, 2014 Assuming you will be using 18mm MDF sealed enclosure The box would be roughly 1.65 cu ft(47 l) (2)(top and bottom 27.09 x 41.48 cm (2) (front and back) 60.96 x 37.67 cm (2) (sides) 60.96 x 27.09 cm Im no pro for the record Check out my build slow but... slow and steady wins the race http://www.stevemeadedesigns.com/board/topic/185561-1st-build-budget-toyota-mark-2/
ace_ventura Posted July 12, 2014 Author Report Posted July 12, 2014 thx mate maybe its just me, but arent the sides a bit long? 60.96 cm x 27.09 cm acording to the rest
Joe X Posted July 13, 2014 Report Posted July 13, 2014 Do you have a pic of the trunk of that car? or a link to it?
ace_ventura Posted July 13, 2014 Author Report Posted July 13, 2014 here are some pics https://www.dropbox.com/sc/io4xz8cp6s2bbdr/AAAjNS1BMK7HWjgWQVZ0iOjYa https://www.dropbox.com/s/vynoiugk5hmrain/DSCN0202.JPG https://www.dropbox.com/s/m8p0io6hfg6alyu/DSCN0204.JPG
Joe X Posted July 13, 2014 Report Posted July 13, 2014 So here is a suggestion, power: to sub(s) rated, amp subsonic filter to 28Hz, minimum port clearance 8 cm, figure is just an assembly guide, try port drivers side first:
ace_ventura Posted July 13, 2014 Author Report Posted July 13, 2014 Thx for the help, realy appreciate this What you mean with try port driver Side first? Would iT be better of i gave the SUbs more power? Because i also have a focal power 1.800 to power them in needed...
