Well I was installing a switch for
My led lights inside my car and accidentally dropped the positive wire and it touched the ground wire and it shorter something out.. I checked every fuse in my car and the one on my head unit and they are fine.. My head unit will only power up if I press the eject button or press the button to display the time.. I have no idea what to do
If all the fuses are good, your next step is to pull the head unit and hook it up directly to the battery. If the problem persists you fried your head unit. If it works you need to test light all the wiring.
Yep just because I didn't want to take the extra minute to disconnect it.. I'm getting a reading from the meter from the yellow wire (battery wire) but not the full 12 volts
Okay well, its not my head unit! My red wire which is the accessory wire isn't giving off any power. All the Fuses are fine. But how would i go about fixing this.. I am completely lost.
  • Who's Online   0 Members, 0 Anonymous, 378 Guests (See full list)
