ADGomez Posted July 14, 2014 Report Posted July 14, 2014 So I was researching on how I would need to setup my electrical for the 4500+wrms audio system I'm about to put in, and I still have a few questions. Somebody please help!! 1) so I am going to use sky high car audio 2/0 ofc wire but I don't know what fuse holder to use? Here's a picture 2)I know I should get fuse depending on the wire rating but I'm not sure what the rating is for 17-20ft of 2/0 wire is this true? : 3) and if it is 700+ amps , shouldn't I get a 700amp anl fuse? Or what I found was a 750amp fuse : Any and all help is much appreciated!
Jhunt94 Posted July 14, 2014 Report Posted July 14, 2014 For the fuse holders it will just come down to preference. One of those accepts ring terminals which means you will have to crimp lugs onto the wires in order to attach them to the fuse holder. The other one will accept the wire directly into a hole, and then you'll tighten a set screw onto it. I'm not exactly sure where you found that wire rating at, but according to this it's not right. http://www.stevemeadedesigns.com/board/topic/1005-wirefuse-guide/ 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter
ADGomez Posted July 14, 2014 Author Report Posted July 14, 2014 For the fuse holders it will just come down to preference. One of those accepts ring terminals which means you will have to crimp lugs onto the wires in order to attach them to the fuse holder. The other one will accept the wire directly into a hole, and then you'll tighten a set screw onto it. I'm not exactly sure where you found that wire rating at, but according to this it's not right. http://www.stevemeadedesigns.com/board/topic/1005-wirefuse-guide/ So according to that it says using a smaller fuse size than recommended is alright, so I can use a 300amp anl fuse? , I just want to double check everything before i fk something up so sorry if I'm starting to get annoying
philrab Posted July 14, 2014 Report Posted July 14, 2014 Running a smaller fuse is fine, as long as its a big enough fuse for your equipment. The danger is running a bigger fuse than the wife's rating. Whole point is to blow the fuse before you melt your wire or blow up a battery. 2015 Toyota Tacoma Build Thread 2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount. Build Thread 1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers. 1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
FCS530 Posted July 14, 2014 Report Posted July 14, 2014 Might I ask what amp you will be running? Several systems, several vehicles. Always changing! 2013 MECA State Champion (trunk 1) 2014 MECA State Champion (mod 4) 2014 MECA state Champion (Park and Pound 4) 2014 DBDRAG 6th place North America Finals (SS1-2) 2014 BASS RACE 6th place North America Finals (139.9)
ADGomez Posted July 14, 2014 Author Report Posted July 14, 2014 Two crescendo bc2000d's and a crescendo 550/2
FCS530 Posted July 14, 2014 Report Posted July 14, 2014 Nice! And subs? Several systems, several vehicles. Always changing! 2013 MECA State Champion (trunk 1) 2014 MECA State Champion (mod 4) 2014 MECA state Champion (Park and Pound 4) 2014 DBDRAG 6th place North America Finals (SS1-2) 2014 BASS RACE 6th place North America Finals (139.9)
FCS530 Posted July 14, 2014 Report Posted July 14, 2014 Guess I should have asked all of this in one post, BUT, what car? Several systems, several vehicles. Always changing! 2013 MECA State Champion (trunk 1) 2014 MECA State Champion (mod 4) 2014 MECA state Champion (Park and Pound 4) 2014 DBDRAG 6th place North America Finals (SS1-2) 2014 BASS RACE 6th place North America Finals (139.9)
