youngbass98 Posted July 19, 2014 Report Posted July 19, 2014 get 2 4 ohm so you can wire to 1 ohm, you can only wire a 2 ohm to 1 or 4, and a 4 ohm to 2 and 8 06 monte carlo 2 12 rockford p3s soundstream rubicon 2500 crescendo audio mezzo 6.5 ct sounds 125.4 execution audio and shca wiring 2 xs d3400 on stock alt
Josh Chav Posted July 25, 2014 Author Report Posted July 25, 2014 lol im trying to start a new forum but i cant find where i go!!
slowfkncar Posted July 25, 2014 Report Posted July 25, 2014 Just run 1. One sub has a heavier coil then the other because of higher resistance, your basically running mix matched sub's. You want them to be equal so you Dont have output cancelation. Its like riding a fucking pedal bike with one long leg and one short leg. One side fucks up the other side.
bkolfo4 Posted July 26, 2014 Report Posted July 26, 2014 Just run 1. One sub has a heavier coil then the other because of higher resistance, your basically running mix matched sub's. You want them to be equal so you Dont have output cancelation. Its like riding a fucking pedal bike with one long leg and one short leg. One side fucks up the other side.Really???There is no mismatch "cancelation". The issue is the current through one if them will be double the current through the other one. Power = voltage x amperage Double power to one of them. Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
