Box Design Help Soundqubed 15
Hey guys I ended up buying a car for stereo and for now while I save up I'm going to put my current equipment In it but I need help with the box design the cars a 96 jetta gl I'd like to do a sealed off trunk sub and port forward with a square port
Equipment DD M80
Soundqubed hds200 15 D2 will be wired at 1 ohm
Max dimensions are 16.5 high
31 wide
34 deep
All I listen to is decaf so I'd like to tune it low around 30 Hz I'm going for strong lows thanks in advance
My setup,
Digital Designs M80
3 Re audio 10's ported tuned to 36 hz
Kenwood x-696
SHCA 0 gauge
Polk audio coax running off hu
So here is a suggestion, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 3 3/4", figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
4 c/f and 3 4" aeros FTMW! ;)
That would need to be 3 19" long ports (same tuning as above), if using PSP flares those would need to be 7 1/4" in diameter, kind of a mess to build right (specially if you want to fit all that in the baffle). Just trying to keep it simple for a potential builder.
that subs can play below tuning on that box without any problems, also, no need to place ports on the same baffle,and no need for 34 hz tuning either, you can use a loading wall to simulate a lower tuning, my suzuki is tuned to 35 hz peaking at 31 hz right now, cheers!
  • Who's Online   0 Members, 0 Anonymous, 11002 Guests (See full list)
