Console build for 94 bronco
Hey guys, this is my first build thread hope you enjoy. I'm the proud owner of a 94 bronco xlt and ive had a couple different setups and now i wanted to change it up and make a console to replace the pos stock one. This console consists of two down firing 8s, going to be running 2 image dynamics ID 8s, in front will be an amp rack for a memphis 250.1 powering the 8s and a infinity kappa 4 channel powering my highs and mids, its going to have three individual 1 & 5/8" cooling fans for the amps, the console will house a 6 switch rocker switch panel, two cup holders and a storage area under the armrest. Btw this is only my third box build and first console. I'll try to keep yall updated as it progresses
20140720_130535_zpscde4f21f.jpg20140720_130541_zps46bdd80b.jpg20140720_130541_zps46bdd80b.jpg20140722_184718_zps416e793b.jpg
1994 Ford bronco
Infininti kappa 4 channel driving a pair of reference 6.5s and a pair of 6x8 kappas
downfiring console w/ a pair of image dynamic 8s on a memphis 250.1
1999 Honda Civic Si
front doors- image dynamics ctx 6" coaxial with ID tweets
Back deck- Image Dynamics ctx 6x9" coaxials
Bass- PSI platform 1 12" in a 4th order tuned to 39hz
Amps- CT sounds 60.4 highs and mids, Ampere Audio 1k bass
Power- Big 3 upgrade, second juicebox 50ah battery, sky high 1/0, skyhigh battery terminals
looks really good. I like console builds
750??! Yeah, fuck that. Fuck this website, fuck SMD, fuck Steve, fuck all of his butt buddy mods, and their couches.
^ DON'T BE A DICK LIKE THIS GUY :)
Team Subsonic Lows
Heres a little update from tonight, i decided where to mount my 6 outlet fused distribution block which will feed the two 12v outlets and my four switches for accessories, to really stick out i spent way to much money on a set of switches that i know nobody around me has, they're oracle lighting's on/off billet led halo switches(picture posted below, mine are on the way). I will also be using a relay(40 amp with 10 amp inline fuse i had lying around) triggered by my head units remote turn on lead to power all three of the cooling fans and to turn on both amps. I cut the top sections tonight that will be glassed over to make a single top that i can remove to access my amps through as well
oracle.flush.mount.red.switch.cropped.jp
mine are in green however, to match the cupholders and rest of the leds in my truck
1994 Ford bronco
1999 Honda Civic Si
  • 4 months later...
1994 Ford bronco
1999 Honda Civic Si
Sorry for the delayed posts guys but heres a little update, been too busy to get much work done on it but I resined it, sanded it down then bed lined it. Its mounted in my truck now, subs hooked up, both amps hooked up and playing. A majority of the wiring is complete but I still need to make the fiber glass top panel pieces, switch panel and armrest
1994 Ford bronco
1999 Honda Civic Si
  • Who's Online   0 Members, 0 Anonymous, 1341 Guests (See full list)
