tmac93 Posted July 26, 2014 Report Posted July 26, 2014 ordered a sundown x 10'' to replace my orion hcca 10''. im hoping to just be able to swap the subs out and use the current box I have. its a sort of trunk wall with a baffle sealing the trunk from the cabin. i did not like the hcca because of not being able to sound very good tuned low. that sub was more of an spl sub with meanings of being tuned higher, wasn't what I was looking for. so found what I believe will satisfy my taste for lows. just hoping it will work out in the box I currently have. im afraid box may be tuned too high? or will it be ok at 34 and play well under tuning? sub box is 1.5cuft, tuned to 34hz, 33sqin of port. this is the information I have on the x 10 d2 if it helps (fs) 27.9hz (re) 3.63 ohms (qes) 0.43 (qms) 4.7 (gts) 0.39 (le) 4.11mh the rest I dont think is needed
ToNasty Posted July 26, 2014 Report Posted July 26, 2014 Your fine ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
Phaeton Posted July 26, 2014 Report Posted July 26, 2014 ordered a sundown x 10'' to replace my orion hcca 10''. im hoping to just be able to swap the subs out and use the current box I have. its a sort of trunk wall with a baffle sealing the trunk from the cabin. i did not like the hcca because of not being able to sound very good tuned low. that sub was more of an spl sub with meanings of being tuned higher, wasn't what I was looking for. so found what I believe will satisfy my taste for lows. just hoping it will work out in the box I currently have. im afraid box may be tuned too high? or will it be ok at 34 and play well under tuning? sub box is 1.5cuft, tuned to 34hz, 33sqin of port. this is the information I have on the x 10 d2 if it helps (fs) 27.9hz (re) 3.63 ohms (qes) 0.43 (qms) 4.7 (gts) 0.39 (le) 4.11mh the rest I dont think is needed no such thing as a trunk wall. As for your sub, i would make a new box. Your sundown sub has different soft parts so it might not work as well as it could. 1997 subaru legacy outback Four 15's in a almost wall Rockford Fosgate t2500-1bdcp Rockford Fosgate T400-4 on tweets Rockford Fosgate T400-4 on highs Rockford Fosgate T400-2 on midrange Rockford Fosgate T400-2 on midbass Optima Yellow top batteries 270A Singer alt (working on a bracket for a second) Lots of Second Skin
