Amp A works Amp B does not Amp A is a -gm-d8601 amp B is a kac-1502s(new) i have the remote on both the amps and the rca is going into the input of amp A the output rca's is going into amp b i have the red flash when the unit is powered i disconnect the rca's and it stops flashing. the only thing i can think of is the ground is not good enough(It's on a source thats part of car it's on a battery that i'm going to install) or the rca's are bad
So you have a Pioneer amp and a Kenwood amp connected together. That might be the problem.
What does this "the ground is not good enough(It's on a source thats part of car it's on a battery that i'm going to install" mean?
SMD Super Seller
My Feedback Thread
it means that it may not be a good enough source, my keyboards a little choppy. I have also tried to connect the rca's from the one thats working to the one that's not so i'm guessing it's not the rca but may be the ground
badicly...you sould not connect 2 different amps together...
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Front/back --- alpine type s 6.5"
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
So you're running this off a car battery?
Does each amp work by itself? If so, refer to my first response. You have two different brands connected together.
I'd like to see pic's of this shit.
SMD Super Seller
My Feedback Thread
i'm running of my car battery to a distribution block to power both amps i have the ground for amp a under my car's seat (07 impala) it runs fine but i have amp b ground only on a battery that's not hooked up in my trunk. i have not swapped the ground from amp a to see if that will do. ill try that tomorrow. but i have tried the remote and rca's and it does othing
you do know that each amp needs ts own ground, and you cant connect grounds from amp a to amp B, it needs t go to the chasis..
and btw...as for information, this forum has plenty of information on how to build your system, and connecting everything..why dont you search a little around it
look at the build logs and see if you have done everything correctly..
  • Who's Online   0 Members, 0 Anonymous, 2417 Guests (See full list)
