what are bat caps?
Bills
KwB
Team DC Audio Midwest captain
I guess it is a matter of personal preference.
Caps are only good as long as your alternator can charge them.
So in his case it may be worth it.
During bass hits the cap is sucked dry, the alternator then has to recharge the cap as well as supply the amp with the current it demands.
I personally would just stick with a H/O alternator and be done with it.
Maybe add a second battery if needed.
ive noticed caps are all good untill you get near 3000rms that TRUE rms lol
but the lil power cells work great so im told
ive had problems with caps useing high wattage..... the cap and the batt drain leaving your alt pulling even more current making your problem bigger as it charges both the bat and the cap while the audio amp(s) pull the power faster than they can charge
low volts with high current draw = fire!
ohh I totally know about caps, I just wanted him to explain why and not just post NO.
Besides he's not running a high wattage system IMO with a 200a alt he should be more than fine.
Busting my balls for no reason. :lol: LoL
no not true, you just cant tell someone NO, without educating them on why.
that bat cap is almost the same thing as The Cap Killer but a diff brand, i've thought about that, and it fits into my plan. that looks good, its like a mini battery, isn't it?
Bills
KwB
Bills
yes... but from what i heard... charges way faster..
I prefer the Kinetik brand batteries, i have a HO 200amp alt with 2 HC2000 and a 5 farad Stinger pro cap for the system and a HC2400 for the truck battery. No major voltage issues running a little over 3000rms to 8 12" woofers
2003 Ford F-150 Reg Cab layin body on 26's
2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine.
2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's
2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
