low pre out voltage?
Okay, so I have a customer who ordered a marine head unit for his boat along with some marine speakers and a marine amp. The head unit is a Kenwood KMR-M308BT for anyone wanting to know. After I got everything wired up I pulled out the handy, dandy DD-1 to do some tuning. I hooked it up to the rca's coming from the head unit and could not get any kind of reading, not even a frequency detect. My first thought was maybe bad rca's, so I checked those and they're good. Then I decided to try to check the output on the head unit using the speaker wires from the head unit's wiring harness and it worked like a charm. I proceeded to retry again on the rca's using a much shorter length and still had the same problem. I pulled out the manual and noticed that it said that the rca out voltage was 500mV and I didn't believe it at first but since I couldn't get a reading I guess that I read that right. So my question is. Is 500mV too low to trigger the dd-1? And if so can that signal be boosted somehow?
250 Mechman Alternator
Sky High Car Audio Big 3
XS Power D3400
Rockford Fosgate 1/0 amp kit
Rockford Fosgate T1500-1bdcp
Rockford Fosgate T400-4
DC Audio Lvl 4 12"
Rockford Fosgate Punch 6x8
Pioneer AVH-P2300DVD
SMD Volt Meter
It does but very faintly, like if you were talking you wouldn't be able to hear it
XS Power D3400
DC Audio Lvl 4 12"
SMD Volt Meter
Yeah I tried that
XS Power D3400
DC Audio Lvl 4 12"
SMD Volt Meter
And I do have the option of high level inputs into the amp, but since I had two sets of sky high rca's I was going to use them, but since I have output on the high level I may just use those.
XS Power D3400
DC Audio Lvl 4 12"
SMD Volt Meter
Yeah, I thought it was strange too, and the yeah I would turn the head unit up to 33 and then turn the gain up on the amp. As far as the amp there are no other settings on the amp other than the gain, I've never seen anything like it. There isn't even a setting for the crossover. The customer bought a package with the head unit, speaker, and the amp. The head unit is a kenwood and the amp and speakers are Pyle which could very much have something to do with it. All of the settings on the head unit as far as the equalizer is concerned are set flat.
XS Power D3400
DC Audio Lvl 4 12"
SMD Volt Meter
Just went back and checked the manual and apparently I read it wrong. The pre out voltage should be 2.5 volts, which should be plenty enough. I'm going to go and play around with the settings when I get the chance. There is a setting when it is in standby mode that changes the pre outs from rear to subwoofer. If it is set on subwoofer it would explain why I'm not getting a 1khz signal through the pre outs.
XS Power D3400
DC Audio Lvl 4 12"
SMD Volt Meter
  • Who's Online   1 Member, 0 Anonymous, 1105 Guests (See full list)
