I have 2 Kenwood KFC-XW1224D's wired to 2 ohms. Plus a SoundStream DTR1.900D. I was reading online about setting the gain with a DMM and wanted to give it a try.
The equation I was told to use was V = (Square Root) of Power x Resistance
Can anyone help me out with which Power should I use? And which resistance?
I read somewhere that the power was the channel power and the resistance was the normal resistance (without wiring)
I was doing v = 600 x 2 and getting 34. Plus I did v = 900 x 4 and got 60.
But when I went out there to test at 50hrz I turned my gain all the way up and was only getting 25v.
Any Input Would Help :D
Not the best way to set gains, but if you have to do it that way.
That amp is only rated for 600 watts rms at 2 0hms. So if your luck 500 rms. therefore it would be 22 volts.
But try to find someone with a dd-1 and do it correctly.
truthsayer
the ct bass knob and some other one (trying to think of the name) is dead on with a dmm.
its not the best way but 90% of the time better then by ear
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
While measuring the amp's output voltage you do have your DMM set to AC volts, right? I've lost count of the times I've seen guys try to use this method of gain setting and had their meters set to DC volts.
2011 Chevy Silverado LT 5.3L 4x4 Ext.-cab
"Enjoy yourself. It's later than you think."
No, a DMM is not the right tool to set gains with. End discussion.
Oscilloscope or a DD-1.
2015 Toyota Tacoma Build Thread
2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount.
Build Thread
1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers.
1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
  • Who's Online   0 Members, 0 Anonymous, 1676 Guests (See full list)
