best 4k monoblock for endurance
Whats the point of putting all this in my car to hook it up to a generator, just because I said its a party car doesn't mean its gonna be in one spot for 8 hours and I do most of the listening inside my car.........I like that FI SP4 as well as the price, probably a 15 in a spec box would be best for my wagon?
With a wagon honestly either one would work. When someone says car, I by default think trunk car, my fault.
Check out my motivitation for a 15" trunk car, JC. This was back before he upgraded to the Fi Team sub. His specs are in the description box. Awesome trunk build.
Wagons are a lot easier to work with imo, easier to "get loud" so either 15 or 18 you'd be good. Also his voltage doesn't seem to be having issues in his vids.
Btw hope you didn't take it like I was ridiculing you, didn't mean it if I came off that way. :drinks:
When I hear music, I fear no danger. I am invulnerable. I see no foe. I am related to the earliest times, and to the latest.
~Henry David Thoreau
Thats a sweet sounding altima, and it did but its cool. The SAZ-3500D might be pushing my electrical too hard so I think the SAZ-2500D would be better but I won't get the most out of the SP4
Do you think you may end up upgrading your electrical in the future? The Tantric HDD 15 is another good choice, 3" coil and a conservative 2500W RMS rating. They can get down on lower power.
http://www.tantricsounds.com/tantric-subwoofers.htm
Lot's of good choices in that range.
Well I will install my custom built 240amp h/o alt, the big 3 and an xs power d3400 before the bass goes in.
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
Yeah but I mean, after that? I'm assuming that you're swapping your stock alt out instead of adding it in addition to the stock one? Maybe a few more batteries later on?
That SP4 is a killer sub, I was just in a similar boat deciding between the SP4, HDD and few other TC basket based subs, but found a local deal on the HDD, plus with my electrical options an SP4 would have a ton of overhead over what I would be able to feed it.
Can't go wrong either way but if you plan on keeping it on a SAZ-2500, I'd go with a 3" coil woofer like the HDD. That SP4 has a higher Mms rating because of the 4" coil, and starts waking up (subjective I know) around 1.5-2kW, but would give you the overhead if you wanted to get that 4kW daily system down the road.
Sig'ed.
I just ordered a XS Power D3400 and the plan is to run 2 but as far as the alt is concerned I doubt there's room for a 2nd alt, like I mentioned in a earlier post, its extremely tight but I would love too have run 2 of them, I will look into that later later, custom alt brackets just sound like a ton of money.
Cool, best of luck with the build. Tuned in for pics
  • Who's Online   0 Members, 0 Anonymous, 722 Guests (See full list)
