max785 Posted August 14, 2014 Report Posted August 14, 2014 Hi,I have an r600-4d 4 channel amp to run my comp. I'm using an pioneer deh-80prs deck which as 5 volt pre-out.The rockford amp is using Input from 150 mV to 4 v according to rf website. I didn't saw this when I bought the amp.Do you guys think the amp is taking the full 5v or limit the signal to 4v ? 2001 civic dx 2 X sa12's " 1 X aq1200d Knukonceptz 4 gauge , rca
SIDE SHOW Posted August 14, 2014 Report Posted August 14, 2014 Interesting, i'd also like to no the answer to this one.....wouldn't think it would restrict it tho.
Noel989 Posted August 14, 2014 Report Posted August 14, 2014 You'll set the gain at zero and won't have to go to the max Unclipped volume on your deck To reach the full potential of the amp Get a dd1 and you'll be all set to go Build Log - http://www.stevemead...-cruiser-el-pt/
SIDE SHOW Posted August 14, 2014 Report Posted August 14, 2014 so does the amp restrict the voltage to 4v?
truthsayer Posted August 14, 2014 Report Posted August 14, 2014 ^^^^^^^^^^^^^^^^ no, but it wont see the 4 volt until HU is turned up. truthsayer
SIDE SHOW Posted August 14, 2014 Report Posted August 14, 2014 so with headunit turned up sending 5v to the amp, the amp will see 5v? or will it reduce the voltage and only accept 4v?
Noel989 Posted August 14, 2014 Report Posted August 14, 2014 so with headunit turned up sending 5v to the amp, the amp will see 5v? or will it reduce the voltage and only accept 4v? It's not a constant 5v So once he hits the 4v he either stops turning it up or he'll go into clipping Build Log - http://www.stevemead...-cruiser-el-pt/
martydmb Posted August 16, 2014 Report Posted August 16, 2014 I have the 600-4t and trust me.. where the dd1+ had set my gains would be too loud. I have the 80prs also. 05 dodge magnum rt DEH-80PRS Rockford fosgate T600.4 st200 tweeters Sundown Neo Pro 6.5 v2's 2 Saz-3500v2- Toolmaker dual 1/0 inputs 2 Sundown ZV4 12" D1 1/0 Sky High Power wire OFC 3 XS D3100- Toolmaker battery terminals Mechman 320 Amp Alt Smd Voltmeter KnuKoncept 1/0 OFC
martydmb Posted August 16, 2014 Report Posted August 16, 2014 Nevermind my bad. My rf amp does more than yours. Should of googled it first my bad 05 dodge magnum rt DEH-80PRS Rockford fosgate T600.4 st200 tweeters Sundown Neo Pro 6.5 v2's 2 Saz-3500v2- Toolmaker dual 1/0 inputs 2 Sundown ZV4 12" D1 1/0 Sky High Power wire OFC 3 XS D3100- Toolmaker battery terminals Mechman 320 Amp Alt Smd Voltmeter KnuKoncept 1/0 OFC
