will it be enough juice??
Wanting to add an auxillary battery to my 02 Yukon. I'm thinking an optima yellow top on the passenger side with an isolator.
I will be running 2 DC 1.2K pushing 2 lvl 3 15's at 1ohm
Also my mids and highs are amplified as well at about 400w rms
Will a 140amp alt and aux batt be enough to support this system?
Thanks in advance!
Never used a second component battery, but from multiple shops around me, I've heard the quote "Friends don't let friends buy Optimas,"
Current Setup: 2002 Ford Focus SE (stock electrical)
-Kenwood Excelon KDC-X397
-Infinity Kappa 6x9's in each door
-Rockford Fosgate Prime R1200-1D
-2 12" Rockford Fosgate P3D2
Backups:
-12" Power Acoustik Mofo-122X in 36hz T-Line box
-Soundstream Piasso P1.1200D
I have 2 optimas in 2 other builds.. they do fine for me.
Also.. why are you isolating anything?
and, for 1k .. 90% of stock elec will be fine.....
I think he means he's going to run (2) 1.2k's @ 1 ohm each.
cool.... still, why the isolator?
and around there a HO alt is looked at, but NOT needed.... IMHO
That is correct.
All in all I will be around 2700-3000 watts rms with all three amps.
Would an xs batt be better? All my electrical will.be coming off the aux battery.
It really depends on what model and type of car the alt. is being put in. Obviously, trucks and SUV's tend to have a little larger alt. stock than sedans and coupes.
Backups:
To separate the batts when the ignition is off??
Just see that most people who run the aux batt use isolators...
No idea about the isolator, and I would think that a good enough second battery would be fine also but you know a shitload more than I do. I just had noticed the 2 1.2k's in the original post.
That is correct.
There's no reason for the isolator.
  • Who's Online   0 Members, 0 Anonymous, 9650 Guests (See full list)
