REH Posted August 18, 2014 Report Posted August 18, 2014 cool.... still, why the isolator? and around there a HO alt is looked at, but NOT needed.... IMHO To separate the batts when the ignition is off?? Just see that most people who run the aux batt use isolators... http://www.stevemeadedesigns.com/board/topic/165488-kylar96-99blazer-populus-singer-xs-shca-cnf/
BigManAC Posted August 18, 2014 Report Posted August 18, 2014 I'm also running around 3k and only have a stock alt and xs bat up front. Maybe later I will upgrade but as of now no HO alts is needed 2001 Saturn L200-Sony MEX-BT4100PFRONT STAGE:- (4) Crescendo PWX 6- Cadence XA250.2SUB STAGE:-Fi Audio BL 15 (Sealed Off)-Crescendo BC2kELECTRICAL:- Singer 240A alt - XS Power D3400- SkyHigh OFC power/speaker wire- Big 3 with SkyHigh 0gaugeBuild Log: Click HereScores: 146.5db @ 29hz Outlaw
Cj Kumz Posted August 18, 2014 Report Posted August 18, 2014 You need power to create power. Lets assume your amps are 80% efficient meaning to produce 3000 watts you need an input of 3750 watts. 3750 w @ 13v (average) is 288 amps. This is the amperage you need at full tilt. But of-course music draws less but you can use that as a reference point. So a 140 amp alt will do but wont be full 3000 w Vw Polo Pioneer Deh-6050UB Sundown Saz-3500d DD Audio 9500 15'' 5.5 cubic feet box with 10 inch port @ 38hz I live to hear the Bass drop!!!
