bc2000d preamp question
bassaholic
so i see in the online manual it says the crescendo bc2000d will go in protect mode if more than 4v is ran to it from preamp. is it possible to run an eq with it or not. my eq has a preamp output of 7v, and im looking at 2 hu with 5v output. even if i go for a 4v hu, what about running the eq. why would they shut off at above 4 volts, my other amps dont. my eq is a clarion eqs746 btw.
do a search for that amp and then see what other people are sending theres...... I havn't used this amp or any other amp that goes into protect when it receives a high input signal.
interested to hear from som1 with this amp
ok so its all about setting gain on amp, doesnt matter if the output is 5v or 7v, as long as on the amp gain it isnt seeing more than 4 volts. so i could run my 7v eq, as long as the gain is set at 4v or below on amp, correct?
  • Who's Online   0 Members, 0 Anonymous, 742 Guests (See full list)
