Hi guys! im kinda new to this whole car audio scene I just want to make sure im doing everything right. Heres my set up
Amp- Soundqubed Q1-1200D
Subs- 2 12" SVC kenwood kfc w3013ps @ 400 rms each
Box- 1.85 cubic feet per side, tuned to 38hz
So i know how to wire my subs to 2 ohms, now how do i set my gain? (510x1@4ohm, 870x1@2ohm,1200x1@1ohm)
Once i have them wired to 2 ohms then can i set my gain on max since they'll be wired at 2 ohms? or 3/4 the way?
Also i will be getting a capacitor soon i just connect that from my batt>cap>amp?
If you need any more specifications let me know..
Thanks for your help.
One don't waste ur money on a cap. Get a secondary battery for the back and set ur gains with a Dd-1 or oscilloscope. Do not turn ur gain to 3/4 or max!
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
I wouldn't get a cap. I would do the big 3 and get a good AGM for up front. And with setting gain, your supposed to match the gain with your HU voltage. So lets say your HU has a 4v pre amp voltave you wouldn't turn your gain to maybe 1/4 if that.. Theres no way to do it perfectly unless you have an oscope or DD1
'97 Explorer
2 Sundown SA 15's
SQ 2200D
Kinetik KHC1800 (Front)
Kinetik KHC 2000 (Back)
KnuKonceptz 1/0 OFC
130A Alt + Big 3
well my HU has 2 sets of 2v preamp outputs (front, Rear) is there any to get close to setting my gain, i know its not going to be perfect but im not going to buy a dd1 or oscope
I.tuned mine by ear and used the.clip light on my.gain knob that came with my amp and on my Sq2200d I'm at a little bit past half gain. I wish I had a dd1 but didn't at the time but it's on my shopping list and I have a 2.5v pre amp voltage
'97 Explorer
2 Sundown SA 15's
SQ 2200D
KnuKonceptz 1/0 OFC
130A Alt + Big 3
So could i just use my knob and play a tone and wait to see if the clip light is coming on? just leave the knob on the lowest setting? also i was going to do the big 3 but ill probs end up messing something up
This is how I did it.
Set volume to 3/4
Play 40 or 50hz tone
Set gain know at half way, this lets you lower or raise your gain depending on the song
Start increasing your gain while watching the clip light and stop once it starts to light up
This is NO way the best way to do it but gives you a start. I would still find somewhere near you with a DD or oscope to help you set it since the gain knob doesnt.actually read where your HU clips so can't get you a very accurate reading
'97 Explorer
2 Sundown SA 15's
SQ 2200D
KnuKonceptz 1/0 OFC
130A Alt + Big 3
Set volume to 3/4
ive read my HU manual front to back no were does it say when it clips..
The head unit manual wont tell you when it clips, you need a tool to be able to tell that.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
Look on the tool map here on the forum. Chances are that there is someone that lives near you with the DD-1.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
