my first big build 3 15 sp4s on ampere 8.0 TFE 4th order blow through 06 avalanche
just got all the bracing done. i will never do this again while the box is already installed in the truck,it was a pita!958B1D14-2382-42B2-AB37-652DF0FC2336_zps
Hey, what did you use to attach down the flanges? (bolts, screws....?)
Btw, pods are looking sweet!
Singer Alternators
Team Asshole
#anothershittysingerbuild
You did a good job on them.
thanks!
i just used some self tapping screws, and i believe some loctite adhesive.
Cool. Thanks!
Progress has slowed down a bit due to work and trying to figure out how I'm going to do all the bracing (besides the pipes).
Singer Alternators
Team Asshole
Cool. Thanks!
yeah I'm trying to hurry before the cold weather hits. also wanna hear your setup when you get it running.
A0EF6CD6-9108-40E0-9704-281A7673FC6B_zpspreview, the pods arent lining up completely right with the doors. there is a gap on the backside,don't no were i went wrong,but at least you can't really see it with the doors closed.
Cool. Thanks!
Yeah, same here! I still have to lay all the deadening material down which is gonna be a pain. And since I have to pull out the floor for that, I'm planning on running electrical at the same time. Was tempted to call off work tomorrow to do it since it's gonna be nice out haha
Also, figured out bracing for the front baffle....posting it in my log in a few minutes.....
Singer Alternators
Team Asshole
If you would have wanted to fix that type of gap behind the pod, easiest is to use some bondo, like Rage Gold. Mask off the door well, mount the pod, add bondo to assure 'no gaps', then sand down, preferrably with some extra 1/32 inch to leave space for vinyl wrapping.
Just a tip for future pod builds.
I think these look really good in general! Seen faaaaar worse! :D
Don't like sharing your knowledge?
Welll.. Don't come here and grab others then! - GTFO.
i feel like an idiot. pods were so hard to wrap because i got the cloth backed vinyl.gonna have to go back to the fabric store and pic a different color,sucks these matched the interior perfectly.it was the only piece they had in this color.there are some wrinkles that i just can't get out.
