Mini Cooper Wall Thread, Version 2
before
Posted Image
Posted Image
Posted Image
Posted Image
oh shit
Posted Image
will clean up the drip marks tomorow when its dry and safe to touch. shit is so messy and sticky and takes forever to get off your hands
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
thats all. we'll see how this helps that support bar from vibrating against the actual metal of the door itself. all that un supported area around the factory support bar ill through some deadening on tomorow after work.
nothing but everything on that door is going to break eventually...rattles like crazy...the bracket the window motor is on is all loose n shit now...lol
Tech Tip, Get you some Blue or Red loctite and every screw, bolt and nut in the door take them out put some loctite on them and put them back in. I guarantee they will stay put. Start with the blue if they back out or loosen up with that on them, Then switch to the red. That will help you out big time!
Hope that helps you out. To all you guys Remember loctite is your friend!
Shannon
Oh, One more thing! Kick @ss Mini man. But I can't believe you did that to the car. CRAZY!
2004 Tahoe.Equipment Kenwood DNX7100 Kenwood Bluetooth adapterKenwood iPod interface cableAudiocontrol DQXSAlpine PDX 4.150Rockford Fosgate punch 40DMS Diamond Audio D363.5 (6.5" Components) Front DoorsDiamond Audio D363.5 (6.5" Components) Rear DoorsJL Audio 15w0's Subs In a 8cu. ft. Box.Monster cable XLN PRO RCA'sMonster Cable 16ga speaker wireMonster Cable 1/0,4ga power, Ground cable.I only got this Monster Cable stuff because I got it dirt cheap. (Crack Head Prices)
