Mini Cooper Wall Thread, Version 2
Guess who got a boner?
8=D~
lol ur not even trin to lie bout lil pimpin r u?? lol so small......
loox great man this cooper is gonna xplode!
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
which one?
I am sorry if my answer is in the thread, but I was wondering if you used birch insted of mdf for weight purposes? Your wall is looking quite awsome. I hope you like this one because it looks like it would be quite the job taking it out.
for sure it will, its hard getting it in, most of it was built IN the car. all of it actually.
and yes, birch was used to save weight as much as possible. mdf is SO much more heavier, and i dont need that extra weight if i can avoid it.
cut out the 2nd baffle. and test fit of the basket for the 18
btw, its bent from the factory, so i gotta call up RE and see whats up...someone failed in china, LOL
the money shot!
angle = 70 degrees
Posted Image
This one.
I did have about thirty equal signs but then though, Why lie.
probably not going to do anything else on the box tonight. tomorow i wanna try and finish the sides and the top.
i changed the oil in the car today as well.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Thewes hahahhahahhaha
Posted Image
i knew he was just building a new seat :lol::D
been working on the back lately, i dont have much more left to do really as far as the trim panel in the rear goes. i love how its coming out.
cut out the rear trim panel, although i knew it wouldnt fit, so i had to 2 piece it to get it in the car.
Posted Image
drivers
Posted Image
passenger
Posted Image
all i gotta do is make a little triangular piece to cover over this mess, and im done with the rear trim panel.
Posted Image
im thinkin since the headliner, side panels, are suede, im thinkin of black vinyl for the trim panel i just put?? ideas here please.
raising the floor a little, this is where ill put things like excess wire, fuses, my 3 way crossover, etc etc. (under the floor)
the floor will be suede as well, thats why i think suede top bottom and sides, then the center trim panel would look good accenting it in vinyl
Posted Image
closed the sunroof, need to cover this in suede, and it wont look bad at all.
Posted Image
this is what looks bad, but no one will ever see it, the sunroof DOES still open though, its just pointless since its sealed off. its very stiff, ive got the 3/4", then a layer of Peel n Seal, then 1/4", then another layer of peel n seal, then the final 1/4" which you see from the inside of the car, which will get sueded.
Posted Image
Posted Image
