new home for 1 sundown x-18 (house set up)
ohmboy
looking for some plans for the house set up i have 1 sundown x-18 running 1100 rms would like to tune low low also it has to be ported all reply's are appreciated
If space is not an issue, it will work great in 15.25 cuft tuned to 17 Hz. Need 70-80 sqin of port if possible. You could go with only 13 cuft net with not much of a change in output.
If you decide to seal it up, 7.5 cuft gives you a Q of .707.
Ported box models up with 7 more dB of output at 20 Hz.
Both setups should play down to ~15 Hz without running out of excursion on 1100 watts.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
That sub should work well in a "MartySub" enclosure, its a fairly popular and easy to build home theater sub design.
Here is the info on it: http://www.avsforum.com/forum/155-diy-speakers-subs/1489541-large-ported-dayton-ho18-s.html#post23711347
Builds:
Ported will have lower frequency response and be louder at the expense of a very large box.
Some will argue that sealed has better SQ, but a correctly designed ported box does just fine.
Current system:
Previous systems:
  • Who's Online   0 Members, 0 Anonymous, 4973 Guests (See full list)
