amp going in protection mode! have good ground and havent blown 60 amp fuse. not hot . 13+volts
fufhubbin
1_4ohmDVC_2ohm.gif its like this except shoot this could be a problem i just realized i have the positive and neg heading to the amp from the same side not opposite like the diagram says to do . Oh shit
ORION HCCA 10.4 2000 watts RMS 4000 watts max
hifonics brutus 2600 bxi
Alpine IDA -305 Digital receiver
0 gauge power wire 250 amp fuse
800 watt BUTTKICKER BASS SHAKER
Kicker zx-400 amp to power buttkicker
doesnt matter which side you do it from as long as you've put the coils in parallel (all + together, all - together).
Hammerdown... 1%
im saying that the wires i put in the subs coils i cut them in half. basicly making it a smaller gauge wire... but just the part that was stripped that i put into the sub sof or a centimeter or 2
you couldn't fit two strands of 8 gauge into each terminal so you split it comeing from the amp? please explain a bit more how you did this
i was specifying which wire i split ... the 2 comming from the amp.. didnt split it at the amp just the striped part i put in the voice coil
  • Who's Online   0 Members, 0 Anonymous, 793 Guests (See full list)
