suggestions on enclosure
300spartan
so i have a orion h2 15.4 sub , its in a prefab box as of right now, but the box blew out from the previous owner so i just screwed everything back together and resealed it and it sucks...
anybody know of a good size box , cu ft? im putting it in a chrysler 300
thanks in advance!
5 cubic feet ported box and 33 hz with a slot port. i dont know the max dimensions of your car nor do i know what you listen to so i cannot help you as well as i could have if you were to post proper information.
1997 subaru legacy outback
Four 15's in a almost wall
Rockford Fosgate t2500-1bdcp
Rockford Fosgate T400-4 on tweets
Rockford Fosgate T400-4 on highs
Rockford Fosgate T400-2 on midrange
Rockford Fosgate T400-2 on midbass
Optima Yellow top batteries
270A Singer alt (working on a bracket for a second)
Lots of Second Skin
Thank you for the quick response, I mostly listen to rap music, and ill have to measure it out tomorrow. i'm very clueless to how to build a box. I've looked thru many sites, calculators, and many formulas but don't seem to grasp the concept. Is there any easy way to determine the cubic ft with port and displacement? I looked up the specs of that sub but end up short. I need help..
Thanks again
i would tune to 30hz, as for cubic feet, im not sure how to explain it. ported boxes: 10's like 1-2.5 cf, 12's like 1.5-3 15's like 3-6 and 18's like 5-8. All of that is roughly estimated. it depends what driver you have and what you want. As for building it, use mdf because its cheap and if you mess up, its not a big deal. some people like nails and glue and others like screws and glue, that part is your preference. screwing mdf requires pre drilling and that eats a lot of time. mdf also likes to crack on you with screws. but whatever you use, use glue and seal your box properly. use silicon and NOT caulking! caulking shrinks over time. you can also fibreglass your corners to seal and add strength to your box. When you build large boxes, you want to brace. how you brace is also up to you. metal pipes, doweling, ready rop or a simple 2x4. Doubling your baffle also helps.
Lots of Second Skin
So here is a suggestion for the Orion H2 15 you have, be aware that dimensions are suggested need to check if they work in your particular vehicle, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 4 1/2", figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
  • Who's Online   0 Members, 0 Anonymous, 2005 Guests (See full list)
