building new box need help
brokedown
I am building a box for 2 sundown sa8v2's that go behind the seat of my regular cab pickup truck. The dimensions i have to work with are 50" long, 11" wide at the base, 6.5" wide at the top and 14" high. I was planning to separate the box in two sections and put the subs facing out the sides add a 3" pvc port like 18"? not really sure what I am doing though so any input would help
Can you show us a sketch of what you have in mind?
For any ported box to work well the port has to have the right area and the right length to get the tuning you desire. I don't know what a 3" diameter port 18" long is going to tune you to, if you don't know either you are not going to have much success with your enclosure.
Builds:
Given your dimensions, the following would work, power to 750W per driver, port clearance 3 9/16" subsonic filter engaged to 28Hz, wood thickness is 3/4", bracing is 1-1 1/4 wooden dowel rods:
the subs are too deep to front mount
I haven't checked in SketchUp but using the design JoeX posted you really should be able to front mount those subs.
Builds:
  • Who's Online   0 Members, 0 Anonymous, 4973 Guests (See full list)
