REH Posted September 14, 2014 Report Share Posted September 14, 2014 I tried plugging the RCA into both input and output and had nothing. and the filters they are all set down. are they not supposed to be? No, your LPF should not be turned all of the way down. For testing, turn that LPF all the way clockwise (You'll change it later, but while you're troubleshooting max it). Subsonic - All the way left Bass boost - All the way left Phase - All the way left. Also, unplug your remote gain knob while you're testing. Link to comment Share on other sites More sharing options...
Ahmed Johnson Posted September 14, 2014 Report Share Posted September 14, 2014 Try hooking an ipod directly to the amp and see what happens Link to comment Share on other sites More sharing options...
MatthewBigBossWilliams Posted September 14, 2014 Author Report Share Posted September 14, 2014 ill check the LPF. hopefully that is the fix Link to comment Share on other sites More sharing options...
MatthewBigBossWilliams Posted September 14, 2014 Author Report Share Posted September 14, 2014 I tried plugging the RCA into both input and output and had nothing. and the filters they are all set down. are they not supposed to be? No, your LPF should not be turned all of the way down. For testing, turn that LPF all the way clockwise (You'll change it later, but while you're troubleshooting max it). Subsonic - All the way left Bass boost - All the way left Phase - All the way left. Also, unplug your remote gain knob while you're testing. I just checked it and it still wont do anything. I messed with the LPF and turned it up and still no sound is being reproduced. all settings are to the left. no gain remote at all. Link to comment Share on other sites More sharing options...
REH Posted September 14, 2014 Report Share Posted September 14, 2014 I tried plugging the RCA into both input and output and had nothing. and the filters they are all set down. are they not supposed to be? No, your LPF should not be turned all of the way down. For testing, turn that LPF all the way clockwise (You'll change it later, but while you're troubleshooting max it). Subsonic - All the way left Bass boost - All the way left Phase - All the way left. Also, unplug your remote gain knob while you're testing. I just checked it and it still wont do anything. I messed with the LPF and turned it up and still no sound is being reproduced. all settings are to the left. no gain remote at all. Try using a different input source, like an ipod or phone mentioned above directly to the amp instead of your headunit. Link to comment Share on other sites More sharing options...
MatthewBigBossWilliams Posted September 14, 2014 Author Report Share Posted September 14, 2014 I tried plugging the RCA into both input and output and had nothing. and the filters they are all set down. are they not supposed to be? No, your LPF should not be turned all of the way down. For testing, turn that LPF all the way clockwise (You'll change it later, but while you're troubleshooting max it). Subsonic - All the way left Bass boost - All the way left Phase - All the way left. Also, unplug your remote gain knob while you're testing. I just checked it and it still wont do anything. I messed with the LPF and turned it up and still no sound is being reproduced. all settings are to the left. no gain remote at all. Try using a different input source, like an ipod or phone mentioned above directly to the amp instead of your headunit. If that does/doesn't work, then what would be the next thing? It is so confusing how it worked for the old amp but not this one. Link to comment Share on other sites More sharing options...
REH Posted September 14, 2014 Report Share Posted September 14, 2014 I tried plugging the RCA into both input and output and had nothing. and the filters they are all set down. are they not supposed to be? No, your LPF should not be turned all of the way down. For testing, turn that LPF all the way clockwise (You'll change it later, but while you're troubleshooting max it). Subsonic - All the way left Bass boost - All the way left Phase - All the way left. Also, unplug your remote gain knob while you're testing. I just checked it and it still wont do anything. I messed with the LPF and turned it up and still no sound is being reproduced. all settings are to the left. no gain remote at all. Try using a different input source, like an ipod or phone mentioned above directly to the amp instead of your headunit. If that does/doesn't work, then what would be the next thing? It is so confusing how it worked for the old amp but not this one. If you've tried all the different settings/controls on the amp, and your other amp works with the exact same wiring.... If you try a new source directly to the amp and it's still a no-go.... then more than likely your amp needs repaired. Link to comment Share on other sites More sharing options...
SIDE SHOW Posted September 15, 2014 Report Share Posted September 15, 2014 your amp is toast Link to comment Share on other sites More sharing options...
MatthewBigBossWilliams Posted September 15, 2014 Author Report Share Posted September 15, 2014 I figured as much. I talked to amazon and since it came from their warehouse, I get to return it with a full refund. is there no way to repair it? Link to comment Share on other sites More sharing options...
swishahouse22 Posted September 15, 2014 Report Share Posted September 15, 2014 I can tell you why it don't work cause its LANZER its cheap shit man I was gonna buy one till my local audio store said don't waste your money cause its not putting out whatever watts its saying [media][/media] Link to comment Share on other sites More sharing options...
