masonv6 Posted September 14, 2014 Report Posted September 14, 2014 I have a aq200.2 that I am going to be using to run my 2 sets of components. For my head unit I have the Kenwood excelon x998. How do I hook the amp up exactly. Since I only have 1 set of inputs on the amp do I use the front or rear set off the head unit. Or doesn't it really matter
Ahmed Johnson Posted September 14, 2014 Report Posted September 14, 2014 It doesn't matter but if you are putting the speakers in the front you might as well run on the front channel and same for rear. But like I said it doesn't matter.
ROLEXrifleman Posted September 14, 2014 Report Posted September 14, 2014 Doesnt mater. you will have no fader capability with a set up like this obviously, and you will be running the amp at hopefuly two ohms depending on the impedance of your comps. For what it's worth I would make sure whatever set of RCA's you use be sure there is no filter on them from the deck Rolex you sicken me. Just let me finish my pie ~ Juice
masonv6 Posted September 14, 2014 Author Report Posted September 14, 2014 I have components for the front doors and the rear deck. Also what kind of filter are you talking about exactly? The speakers will be running at 4ohms each. They will see around 110 to 120watts each.
masonv6 Posted September 14, 2014 Author Report Posted September 14, 2014 would I be able to have fading with a product like this http://www.sonicelectronix.com/item_45078_NVX-XIV2M.html
masonv6 Posted September 14, 2014 Author Report Posted September 14, 2014 Hook the front channel lets say to the L side and the rear channel to the R side. IDK if this would work for sure
islandpride684 Posted September 16, 2014 Report Posted September 16, 2014 will this work? Nope Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
islandpride684 Posted September 16, 2014 Report Posted September 16, 2014 would I be able to have fading with a product like this http://www.sonicelectronix.com/item_45078_NVX-XIV2M.html You would use this to make a 2 channel to 1, a 4 channel to 2...using only one set of RCA outputs from the headunit...lets say you want to use a 2 channel amp just for the fronts, you would run the front rca on the headunit to these adapters connected to channel 1 and 2 of the amp... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
