JoshCorley Posted September 20, 2014 Report Share Posted September 20, 2014 So after using the tool for a while I have noticed something some amps going from alpine pdx to option audio and everything in between. Some amps have polarity back to front, well that's what I assume. I noticed with the dd1 sometimes it doesn't detect a signal and if I move to the negative pin of the amps output it will work correctly anyone experienced this? Link to comment Share on other sites More sharing options...
OrionStang Posted September 20, 2014 Report Share Posted September 20, 2014 It states in the manual that sometimes the negative speaker output will act as the positive signal. Sundown amps are notorious. Whats the problem, you didn't read the manual? SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
JoshCorley Posted September 20, 2014 Author Report Share Posted September 20, 2014 What I mean is going from left speaker to right speaker is different Link to comment Share on other sites More sharing options...
SnowDrifter Posted September 20, 2014 Report Share Posted September 20, 2014 One side of the amp has a constant voltage. The other side gets modulates for your signal output. That would make sense. You can't get a signal from a DC reading And yes, some amps will change depending on left vs. Right channels. Makes it so the amp can be bridged without a bridge switch. Just hook up wires and go ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
JoshCorley Posted September 20, 2014 Author Report Share Posted September 20, 2014 Snowdrifter thank you for the reply that makes more sense now Link to comment Share on other sites More sharing options...
