dd1 weird issues amps at fault
JoshCorley
So after using the tool for a while I have noticed something some amps going from alpine pdx to option audio and everything in between.
Some amps have polarity back to front, well that's what I assume. I noticed with the dd1 sometimes it doesn't detect a signal and if I move to the negative pin of the amps output it will work correctly anyone experienced this?
One side of the amp has a constant voltage. The other side gets modulates for your signal output. That would make sense. You can't get a signal from a DC reading
And yes, some amps will change depending on left vs. Right channels. Makes it so the amp can be bridged without a bridge switch. Just hook up wires and go
  • Who's Online   0 Members, 0 Anonymous, 839 Guests (See full list)
