KickerCherokee Posted October 2, 2014 Author Report Posted October 2, 2014 So here is a suggestion, power: to sub(s) rated, amp subsonic filter to 28Hz, minimum port clearance 5", figure is just an assembly guide, bracing is 1 1/2 wooden dowel rod: Thanks dude! It's perfect,but i have a problem to convert inches to cm :/ In Greece we use cm and for example 11 iches are easy to convert,but i cant convert 11 7/16... :/
Joe X Posted October 2, 2014 Report Posted October 2, 2014 Yes, besides wood thickness is slightly different in countries that use metric units, let me know if you can get 18 mm wood which is the nearest to 3/4".
KickerCherokee Posted October 2, 2014 Author Report Posted October 2, 2014 18mm?It's strenght enough?I can find 20mm wood...And the other dimensions 7/16 , 1/2 are wood thickness? If you can convert those dimensions for me i will love you! Haha!
Joe X Posted October 2, 2014 Report Posted October 2, 2014 18 mm is good, it's almost 3/4", that would be good, if you can only get 20mm that would work as well, little bigger box though. Let me know.
KickerCherokee Posted October 2, 2014 Author Report Posted October 2, 2014 At the cut sheet list you say, 5 11/16(?) 25 1/2(?)I highlated the spots that i cant guess...You cant convert me the cut sheet to cms?That would be very great....Sorry for being tiresome but i will mess up with the woods
Joe X Posted October 2, 2014 Report Posted October 2, 2014 So here is another couple of suggestions, same as above but converted to metric units for two different wood thickness, power: to sub(s) rated, amp subsonic filter to 28Hz, minimum port clearance 13 cm, figures are just an assembly guide: 18 mm wood thickness: 20 mm wood thickness:
KickerCherokee Posted October 2, 2014 Author Report Posted October 2, 2014 I really love you! Thanks for the help mate! I will give photos when i fix it! REAAAAALYYYYYY THANK YOU!!!!!!!!
