The Norwegian Wolf - Pajero walled with 8 12s on 14KW+
Today I got the right-side wall in and first layer at the back. Also started drilling up holes in the bus bars. Things are not going as fast as i hoped for but there is defenitely progress.
d2689425bb797022c31781b2f2f3c844_zps84ff
7ddef1eefc94c17131c8a423f8b1630f_zpsb5b2
ce4da5628e71ce25b97c13ca981b36c5_zps5d5c
0a309fb3ef935146baa52199de5fb4e9_zpsc27d
e9ea6f436740f888bf18bbcc6b15f293_zpsf92a
Time for a small update again. I have managed to get some more small progress.
Shell seen from the side.
76f3db1c7ea91a083ce7f4b7dbc8a518_zps5383
Baffle layout, the port will be above this, so no need to cut it out from this sheet.
01319325703d8a072c9a03942eefd3e8_zps6b40
Second layer of roof pushed into place by force.
f3344c5587b895b2783ea7a50c29bed9_zpsb25c
Tigh fit.
39c9d49f700511b6cbe9434f21eee403_zpsf5c1
Have started laying some fibreglass filler. corners on the back wall will be rounded over using PVC pipe and fibreglassed on top of that.
77e7ce90b814c8c8df4136aa537688bf_zps8bba
Thanx zrkie. A fellow Scandinavian!
Yep, they aren't too different from SPL dynamics that is true, I did consider that brand. But I got a Finnish friend to check their prices if bought in Finland, even there they were a bit more expensive, remember I am using 8 woofers. Anyway thanks for checking out the build. I'm going out to cut som holes in some baffles, what a job!
Tuned in!
This build is going to be very intresting.
Use spl dynamics d1 12" myself and they seem to look almost the same as your lib.
I live for music!
Things are moving forward. I used a quarter of a PVC pipe cut lengthwise to round of some inner corners in order to help guide the airflow into the port. The plastic is just held in place with glue before getting glassed over. A little bit of aerodynamic thinking can't hurt. All joints are glassed over, And the entire inside recieved a good couple of layers of resin as well.
e13fa5980da5904712fa3937e2f803b4_zps2089
48555e18992b61bf3b8e2ecad114f30f_zpsb979
2ece42a56bfa3be1045d39d0a66a2b7b_zpsa0a1
Then I did a couple of layers of fibreglass mat on top of the rounded corners.
cfe670da96fe010e276d572d2aa09ccc_zps083f
First layer of glossy white paint.
d12ddad22cf008a1e9e16b53940077ff_zpsee7e
Yes I know it's just a shell so far. Not too exciting really.
3b2f973fda6cf0df7359c70146e7c39b_zps1e50
Plenty of excitement dude, good shit
The L@zy Hoe
2005 Chevy Tahoe
2,500 Watts of Highs/Mids
4 10 midrange
4 6.5 midwoofers
4 Tweeters
6 Supertweeters
2 Lithium 80AH Batteries
24K Watts
4 Custom 18s
Quad alt setup Rebuilt 250amp and 3 370s
Interior work by Lone Star Auto Works
The Build Log
Like Loud Bass? Click Here!
On 12/5/2014 at 8:06 PM, juan777 said:
See yall there, I'll be the drunk Mexican with aviators on.
On 12/6/2014 at 10:32 PM, boom50cal said:
I did see Juan LMFAO! He REALLY WAS the drunk mexican with Aviators on!
Allright I have gotten a whole lot of work done.
ab92e084e3deabe25b6036896dd30804_zps4ad5
acb6c06bc5cd50cc19306ccdd3af19e3_zps2e8d
610cbb8e469e39f6bcbcede2dbcf477b_zps2727
2f566c5e718ea08affa346d34e021698_zpse8bc
10ad671d97663580b1affac5fcff62cc_zpsc10d
The entire baffle was coated in resin.
2x3" wood for side to side bracing.
3af065a855d6b20f49f6ddeeea5248e0_zps7b8b
13e63cda7297e0a4deec7068f4a6f773_zpsaee5
I ran the speaker wire along underneath that brace. It worked out well and I was glad I did it since eight DVC woofers means a whole lot of wiring to be done.
5042759b7f618efb081f8cef4312ecae_zpsbbc6
Also got the port in place. It is 4,4cm thick as I intended it to have a bracing function as well.
Yes, the port has some funny angles which makes it a bit tricky to say the least. However I just didnt have space for a normal port at the side.
74cb19a5f065b5f471d8a6a782cca704_zpsebee
17756c889e808fd922dbf89d15698b5c_zps847b
05f85785382ebdd5ffca5d5ca7c3ffeb_zps26aa
Started working with fibreglass filler. What a joy.
9c203744c25048f41a3ece6b4e5e4088_zps581d
The backside. Still a lot of work to do in that area.
137b33f941af7d762205de2af1ad371c_zpsa8ff
8c2ebe83c646fa94b64c6676f644b4a1_zps96aa
Wiring for two amps in
b0d4a1d2262b68004e6f1a437b214f2a_zps3caf
5ddd1a332694d24cd6f68b295f34879b_zps377a
66068ed598e4e8d0fc04cd1d6e6ba7e4_zpsfb5b
Ran into some obstacles when installing woofers.
13f81fa2cf967d253a5917657d28a90b_zps0a06
But I GOT THEM ALL IN!
ceddaa336f2f129c55199c98460ba053_zps7f9f
