AstoSoup Posted December 30, 2014 Author Report Share Posted December 30, 2014 Joints of the wood came out really even and with just a little sanding with a palm sander, will be nice and smooth for the coat of poly Got baffle? lol Head Unit - Clarion VX709 7" DVD Touchscreen Mid/Highs - Front Doors - RF Prime 6.5" component mids. A. Pillars - RF Punch component tweets. B. Pillars - RF Prime component tweets. Rear Doors - RF Punch 5.25" mids. RF Punch 3-way passive X-overs. Mid/Highs Amp - MB Quart Onyx 360.4, 4 channel, 640W RMS. Subs - (2) PowerBass 3XL 15, 1000w RMS, 3" flat wound coil, 562oz motor, 10" spider. Sub Amp - Audiopipe GD6001 @.5ohm, clamped 2825RMS. Box - 9.6 cu^3 net @35Hz, three 6" aero's. Charging - Energizer 120Ah AGM under the hood, MaxLife 75Ah in the rear. Big 3, 140A aftermarket alt. (off brand) Wires - Two JL Audio 2/0ga OFC. runs to rear, 4ga. power/2ga. ground to component amp (OFC), 1/0ga. OFC Knu Konceptz Kolossus Kandy everywhere else. Link to comment Share on other sites More sharing options...
AstoSoup Posted December 30, 2014 Author Report Share Posted December 30, 2014 Then, after some procrastination, lol... Got the sub holes cut! Had to grab a new 5A jigsaw, as my old 1980's saw would not cut the two layers of birch. Picked up some 1/2" threaded rod, nuts and large washers for horizontal supports. Will run across the box right around the placement they are on the top.... So far, this is where I am at.... Will get the three, 6" aeros in and the bracing done this week, sand it smooth and give it a try before I do the coat of poly. Once the box is complete and subs are in, I just need to install the 4 mid ranges and get a bigger amp! lol. Thinking of going with a Crescendo BC2000D @.5ohm, as my class limits me to 2.5k RMS. Head Unit - Clarion VX709 7" DVD Touchscreen Mid/Highs - Front Doors - RF Prime 6.5" component mids. A. Pillars - RF Punch component tweets. B. Pillars - RF Prime component tweets. Rear Doors - RF Punch 5.25" mids. RF Punch 3-way passive X-overs. Mid/Highs Amp - MB Quart Onyx 360.4, 4 channel, 640W RMS. Subs - (2) PowerBass 3XL 15, 1000w RMS, 3" flat wound coil, 562oz motor, 10" spider. Sub Amp - Audiopipe GD6001 @.5ohm, clamped 2825RMS. Box - 9.6 cu^3 net @35Hz, three 6" aero's. Charging - Energizer 120Ah AGM under the hood, MaxLife 75Ah in the rear. Big 3, 140A aftermarket alt. (off brand) Wires - Two JL Audio 2/0ga OFC. runs to rear, 4ga. power/2ga. ground to component amp (OFC), 1/0ga. OFC Knu Konceptz Kolossus Kandy everywhere else. Link to comment Share on other sites More sharing options...
StigA Posted December 30, 2014 Report Share Posted December 30, 2014 Nice build! Are you going to have the subs inverted? Think it will look cool.. Keep up the good work! Link to comment Share on other sites More sharing options...
AstoSoup Posted December 30, 2014 Author Report Share Posted December 30, 2014 Nice build! Are you going to have the subs inverted? Think it will look cool.. Keep up the good work! Thanks! And I want to, will give me more airspace in the box as well as look awesome Gotta figure out tuning and all that when I put the ports in and figure out how to calculate bracing displacement, then I will know which way the subs will go. Too much math for me, lol was always my weak subject : / Head Unit - Clarion VX709 7" DVD Touchscreen Mid/Highs - Front Doors - RF Prime 6.5" component mids. A. Pillars - RF Punch component tweets. B. Pillars - RF Prime component tweets. Rear Doors - RF Punch 5.25" mids. RF Punch 3-way passive X-overs. Mid/Highs Amp - MB Quart Onyx 360.4, 4 channel, 640W RMS. Subs - (2) PowerBass 3XL 15, 1000w RMS, 3" flat wound coil, 562oz motor, 10" spider. Sub Amp - Audiopipe GD6001 @.5ohm, clamped 2825RMS. Box - 9.6 cu^3 net @35Hz, three 6" aero's. Charging - Energizer 120Ah AGM under the hood, MaxLife 75Ah in the rear. Big 3, 140A aftermarket alt. (off brand) Wires - Two JL Audio 2/0ga OFC. runs to rear, 4ga. power/2ga. ground to component amp (OFC), 1/0ga. OFC Knu Konceptz Kolossus Kandy everywhere else. Link to comment Share on other sites More sharing options...
StigA Posted December 30, 2014 Report Share Posted December 30, 2014 Nice build! Are you going to have the subs inverted? Think it will look cool.. Keep up the good work! Thanks! And I want to, will give me more airspace in the box as well as look awesome Gotta figure out tuning and all that when I put the ports in and figure out how to calculate bracing displacement, then I will know which way the subs will go. Too much math for me, lol was always my weak subject : / I see, going to be super! About tuning, have you tried WinSD or Torres box calculator? These programs have been much help for me. Anyway, it should not be any problem to get some help on this forum. Link to comment Share on other sites More sharing options...
hoit Posted December 30, 2014 Report Share Posted December 30, 2014 everything is looking great! I really thought you would get more positive feedback than you have...none the less, keep up the great work! lots of pics are always looked highly upon!! 2007 Chevy Aveo Ls sedan 2 Sundown Xv2 on scv4k @ .5 ohm 2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm Big Three, Three runs 1/0 power from front to back, 1 ground front to back Two runs ground from rear bank to chassis XS power d3100 upfront, 3 Odyssey 2150s in bank Singer 220 amp alt Link to comment Share on other sites More sharing options...
AstoSoup Posted December 31, 2014 Author Report Share Posted December 31, 2014 everything is looking great! I really thought you would get more positive feedback than you have...none the less, keep up the great work! lots of pics are always looked highly upon!! Thanks! And I don't think it's a big enough deal for all the hype or something, lol. I think it's coming real nice though, thanks for following! And I have the tuning down, all except trying to determine brace displacement. Can't figure out how to go about measuring the cu. in. Head Unit - Clarion VX709 7" DVD Touchscreen Mid/Highs - Front Doors - RF Prime 6.5" component mids. A. Pillars - RF Punch component tweets. B. Pillars - RF Prime component tweets. Rear Doors - RF Punch 5.25" mids. RF Punch 3-way passive X-overs. Mid/Highs Amp - MB Quart Onyx 360.4, 4 channel, 640W RMS. Subs - (2) PowerBass 3XL 15, 1000w RMS, 3" flat wound coil, 562oz motor, 10" spider. Sub Amp - Audiopipe GD6001 @.5ohm, clamped 2825RMS. Box - 9.6 cu^3 net @35Hz, three 6" aero's. Charging - Energizer 120Ah AGM under the hood, MaxLife 75Ah in the rear. Big 3, 140A aftermarket alt. (off brand) Wires - Two JL Audio 2/0ga OFC. runs to rear, 4ga. power/2ga. ground to component amp (OFC), 1/0ga. OFC Knu Konceptz Kolossus Kandy everywhere else. Link to comment Share on other sites More sharing options...
AstoSoup Posted January 3, 2015 Author Report Share Posted January 3, 2015 Got some more goodies in the mail today! Got the orange/black 8ga. speaker wire to match the rest of the orange and black wiring. It's Execution Audio, which isn't the greatest but the AWG is true and I will be going such a short distance, I don't think it will matter. Besides, it looks nice Head Unit - Clarion VX709 7" DVD Touchscreen Mid/Highs - Front Doors - RF Prime 6.5" component mids. A. Pillars - RF Punch component tweets. B. Pillars - RF Prime component tweets. Rear Doors - RF Punch 5.25" mids. RF Punch 3-way passive X-overs. Mid/Highs Amp - MB Quart Onyx 360.4, 4 channel, 640W RMS. Subs - (2) PowerBass 3XL 15, 1000w RMS, 3" flat wound coil, 562oz motor, 10" spider. Sub Amp - Audiopipe GD6001 @.5ohm, clamped 2825RMS. Box - 9.6 cu^3 net @35Hz, three 6" aero's. Charging - Energizer 120Ah AGM under the hood, MaxLife 75Ah in the rear. Big 3, 140A aftermarket alt. (off brand) Wires - Two JL Audio 2/0ga OFC. runs to rear, 4ga. power/2ga. ground to component amp (OFC), 1/0ga. OFC Knu Konceptz Kolossus Kandy everywhere else. Link to comment Share on other sites More sharing options...
AstoSoup Posted January 3, 2015 Author Report Share Posted January 3, 2015 Also got some Dayton aluminum 8" mid bass woofers that will go in the kick panels. Will pick up frequencies above 120Hz, for the vocals and mid bass tones. These 8's are very heavy and beefy little suckers for the $32 I paid each! They are the "ultra low distortion" model, so I expect some clean vocals! Head Unit - Clarion VX709 7" DVD Touchscreen Mid/Highs - Front Doors - RF Prime 6.5" component mids. A. Pillars - RF Punch component tweets. B. Pillars - RF Prime component tweets. Rear Doors - RF Punch 5.25" mids. RF Punch 3-way passive X-overs. Mid/Highs Amp - MB Quart Onyx 360.4, 4 channel, 640W RMS. Subs - (2) PowerBass 3XL 15, 1000w RMS, 3" flat wound coil, 562oz motor, 10" spider. Sub Amp - Audiopipe GD6001 @.5ohm, clamped 2825RMS. Box - 9.6 cu^3 net @35Hz, three 6" aero's. Charging - Energizer 120Ah AGM under the hood, MaxLife 75Ah in the rear. Big 3, 140A aftermarket alt. (off brand) Wires - Two JL Audio 2/0ga OFC. runs to rear, 4ga. power/2ga. ground to component amp (OFC), 1/0ga. OFC Knu Konceptz Kolossus Kandy everywhere else. Link to comment Share on other sites More sharing options...
AstoSoup Posted January 3, 2015 Author Report Share Posted January 3, 2015 Oh, and I did manage to get enough time to get more work done on the box! Did all 4 corners with a 45 brace, for more strength and smoother air movement.... Weekend is here, will get the two rod braces in and the ports and hopefully give it a test run! Head Unit - Clarion VX709 7" DVD Touchscreen Mid/Highs - Front Doors - RF Prime 6.5" component mids. A. Pillars - RF Punch component tweets. B. Pillars - RF Prime component tweets. Rear Doors - RF Punch 5.25" mids. RF Punch 3-way passive X-overs. Mid/Highs Amp - MB Quart Onyx 360.4, 4 channel, 640W RMS. Subs - (2) PowerBass 3XL 15, 1000w RMS, 3" flat wound coil, 562oz motor, 10" spider. Sub Amp - Audiopipe GD6001 @.5ohm, clamped 2825RMS. Box - 9.6 cu^3 net @35Hz, three 6" aero's. Charging - Energizer 120Ah AGM under the hood, MaxLife 75Ah in the rear. Big 3, 140A aftermarket alt. (off brand) Wires - Two JL Audio 2/0ga OFC. runs to rear, 4ga. power/2ga. ground to component amp (OFC), 1/0ga. OFC Knu Konceptz Kolossus Kandy everywhere else. Link to comment Share on other sites More sharing options...
