Planning my first system
As the title says I am planning for my first system. I bought at ct sounds 1400.1 and plan on buying a ct 60.4. I am trying. To decide on either 2 10s 2 12's or a single 15. I have looked into soundqubed hds15, ct sounds meso 15, sundown x 12 and 2 sundown sa12s. I am looking for a good sounding woofer to listen to country and rock. But I want something that will bang when I turn it up. Any suggestions or advice are welcome.
I suggest you read the forum rules regarding vs. threads and edit your post.
2015 Toyota Tacoma Build Thread
2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount.
Build Thread
1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers.
1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
^^^^ What he said
Currently whipping a O4' GMC Sierra 2500
Performance:
K&N Cold Air Intake
Hedman headers
3" True duels
Flowmaster Super 10's
Magnaflow High Flow Cats
G2 4:88 running gears
New cooling system
Superchips Flashpaq programmer
Eaton lockers
Audio: JL CP208W3V3
Kenwood X500-1
8 Gauge Memphis Power wire
Kenwood DDX8901HD
Exterior:
Fabtech 9.5" lift
38x13.5 Toyo Open Country M/T's
18x10 Fuel Mavericks (-44 offset)
Diamond plate bed gaurds
Diamond plate tool box
Recon Xenon Bulbs in Highs,Lows,& Fogs
Recon LED Tail lights
AMP Research Automated steps
I'm not limiting the post to those woofers. Those are just some I've seen. I just want to know what to look for in a sq woofer.
should probably figure out the size of the woofers first.
what vehicle?
Mk4 jetta. I don't want to use the entire trunk so I have around 4 cubes. Can't fit anymore than a 15 height wise.
2 10s. need space for batts, amps, all the extra stuff.
http://shop.ct-sounds.com/product/strato-1-0-10-subwoofer
They have strato 10s for super cheap I would do 2 of those. If it was me and you already bout ct sounds go all ct.
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
The Sundowns should perform pretty well with all types of music. There is just so many different factors when making a system. I recommend looking on threads of people in the same situation as you.
Performance:
K&N Cold Air Intake
Hedman headers
3" True duels
New cooling system
Eaton lockers
Audio: JL CP208W3V3
Kenwood X500-1
Kenwood DDX8901HD
Exterior:
Fabtech 9.5" lift
Performance:
K&N Cold Air Intake
Hedman headers
3" True duels
New cooling system
Eaton lockers
Audio: JL CP208W3V3
Kenwood X500-1
Kenwood DDX8901HD
Exterior:
Fabtech 9.5" lift
  • Who's Online   0 Members, 0 Anonymous, 12355 Guests (See full list)
