Two amp's are also more efficient than one. How do you know if you're wired at 1 ohm you will rise to 2 ohm's? Guessing has no place in reality. If it was me I'd do two amps over one.
Don't be so concerned with impedance rise. It's going to happen regardless of your amplifier setup.
What kind of amplifiers are you thinking about getting?
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
Ah ok. Thanks. Heard it said that rise is normally between 1-1.5 times the nominal load. I know this is not the correct way to go about it but im going to need the amp/amps before I do the install and cant test my rise until the install is complete. I have never ran multiple sub amps and im still learning so bear with me.
Rise is build dependent there is not a set number.
Well in this case then get the dd over crunch any day. this shouldn't have even been a question unless the amps were on par with each other quality wise. Also make sure your electrical is good enough for what you're trying to do
Get the DD for sure. That's not even a hard choice.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
Yeah I know. The only way I can get an idea is by going by the norm since my current setup is going to be totally different than the new one. Just trying to get an Idea about amps. Definetly going to run the strapped amps. I really appreciate your help.
You'd be better off with the single DD...
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
  • Who's Online   1 Member, 0 Anonymous, 818 Guests (See full list)
