System for my Chevy Colorado Extended Cab
Hello every im new here and I hope im posting in a appropriate section.
So I've decided I want something louder in my Colorado Right now I have 2x15 Kicker CVRs which are okay I guess I have a 2000 watt performance teknique amp.
I want to cut my bed and put anything I can fit in there. I want something LOUD preferably 15 or 18 inch subs but I dont know where to start I want something made to last but not to expensive. Can you guys give me some ideas?
First you said cut the bed and put anything that will fit. So right there the sky is the limit.
Second you said built to last but not expensive. We dont know what expensive is to you and those two dont generally go hand in hand.
Third LOUD. My rooster crowing at 4am is LOUD.
I dont mean to be a dick Im just pointing out that we could use a little more info from you to narrow things down that will help you. If not then you are going to recieve tons of posts that will be of no help.
Still learning but have started gathering.
4th- definatley get a new amp
3 15's, firing forward, port up on 5k. Below window line, does 155ish on music.
@ColoradoDream
sounds kickass too.
wait you have 2 15s now? so you must have a extended cab. you don't need to cut your bed apart to get loud.
first real question is hows your electrical?
you need to build that up first! meaning 0g run from main agm battery to amp (or second battery if your really Gonna run a true 2000+watts) the big 3 and if you want over 3k a ho alt or more bats. once that is out of the way we can talk about subs. a lower price and beast sub is the fi bl. 99% of the people here will say it's a great sub. for $300 a pop 2 15s on 2 or 3k will rock your truck!
but just a heads up cutting your bed, also a blow threw is some work. you need to get some more knowledge under your belt.
not to sound jerkish but you need to get away from kicker and whatever your amp is and get some true subs
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
