Box design for 2 Massive Toro
evermaxx
Friend needs a box design
2 Massive Toro's
I tried finding info on subs but can't find much for em.
30 w
16 h
24 d
Subs & port forward.
Thanks guys.
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
Subwoofer Series
Toro (Massive Audio)
Peak Power Handling
2400 watts
RMS Power Handling
1200 watts
Voice Coil(s)
Dual
Impedance (Per Voice Coil)
4 ohms
Voice Coil Diameter
2.55"
Sensitivity
84.7 dB
Xmax (millimeters)
12.6 mm
Subwoofer Design
Round / Circle
Woofer Composition
Pressed Pulp Fiber
Woofer Surround
Rubber
Magnet Structure
Double Stacked
Subwoofer Grille
No
Re-Cone Kit Available
No
Recommended Enclosure Specifications
Recommended Enclosure Type
Ported / Vented
Sealed
Minimum Sealed Box Volume
1.80 cubic feet
Optimum Sealed Box Volume
Maximum Sealed Box Volume
1.80 cubic feet
Minimum Ported Box Volume
3.5 cubic feet
Optimum Ported Box Volume
Maximum Ported Box Volume
3.50 cubic feet
Top-Mount Depth
8-4/16"
Cutout Diameter
13.90"
Shallow Mount Installation
No
Electromechanical Parameters
Free-Air Resonance (Fs)
35.7 Hz
Equivalent Compliance (Vas)
59.668 liters
Total Speaker Q Value (Qts)
0.839
Electrical Q Value (Qes)
1.422
Electrical Resistance of Voice Coil (Re)
3.60 ohms
Mechanical Q Value (Qms)
2.046
specs
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
Based on the specsheet posted above (12D4 subs) here is a suggestion, power: to sub(s) rated, amp subsonic filter to 32Hz, minimum port clearance 4", figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
  • Who's Online   0 Members, 0 Anonymous, 1766 Guests (See full list)
