What type of RCA cable's should i use?
Found my answer in the comments.
DAmoreEngineering:
If the head unit has SE outputs and the amplifier has SE inputs = coax cable If the head unit has SE outputs and the amplifier has Diff inputs = twisted pair If the head unit has Diff outputs and the amplifier has Diff inputs = twister pair If the head unit has Diff outputs and the amplifier has SE inputs = bad no matter what as you will shorting out half of the head unit's outputs. In this case you would need an amplifier with Diff inputs or a converter to convert the head unit's outputs to SE
I'm going to take a guess here
Based on the fact that pioneer cd players have the infamous "pico fuse" on the ground side of the RCA would it be safe to say that they are se? I mean clearly they are grounded.
Fyi,
For anyone with RF amps, their tech explained to me that the design of their amps allow for the use of either type of RCA wires.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 1125 Guests (See full list)
