dscid Posted November 5, 2014 Report Posted November 5, 2014 With 4v HU running to 7v Clarion EQ, that is in transit, should I be concerned at all? I know some people say it can introduce noise - but is that just due to bad grounding? I also have read that it could overload the inputs of the amp, causing early failure (some day), as well as running them hot, and adding noise? Anything I should be prepared for?
SIDE SHOW Posted November 5, 2014 Report Posted November 5, 2014 as long as you install the amp correctly and set it up with the appropriate gear you should be fine.
Wicks Posted November 6, 2014 Report Posted November 6, 2014 Look up the max RCA input voltage (~2.5 to 6V) for your amps and make sure the EQ is set to that level and not higher, otherwise you could clip the amps input. This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
