I'm looking to build a new setup and going bigger! My new setup is an Incriminator Audio Flatlyne 15" DVC 2Ohm wired @ 4 Ohm load and powered by a Rockford Fosgate P1000X2 bridged @ 4 Ohms. I was thinking of building a slot ported box but am open to ideas. The problem I'm running into is not really finding a lot of other input for this subwoofer (I like hearing what has worked for other people as a general guide) and also what software to use to get the most accurate information and box specs. I've gone between several tools by reading what others have recommended to find box size for different types of boxes and each site gives me very different results. Anything from 4ft3 to 9ft3 for a box. My trunk limitation is around 4ft3 to 5ft3 and I would really just like some ideas or input on where to go and what to build. If anyone can help or point me in the right direction, I'd appreciate it! Thanks!
Well that's the thing. I've used manufacturer specs and plugged them into several reputable box calculators only to get a wide variety of box sizes and even mixed answers on whether the subwoofer should be in a ported or sealed box. I can post all the specs, although it's a quick google search. I just don't know what box size to believe, all based on the same specs.
is the forte a sedan? if so make sure you can load threw the trunk! most 15s don't like to fit in a cars trunk!
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
Aj11, yes it's a sedan. Decent trunk size I think, if I can't fit a 15" I'll go down to 12", but that depends on what size is needed :P
Thanks islandpride684, I had no idea there was a forum for IA, I'm now going though that and have gotten all the information I need! Thanks!
Actually after reading over the forums this is the information from the post:
Flatlyne Series
12" DVC2 & DVC4 ohm
closed 28.3 - 39.6 liter
ported 42.5 - 56.6 liter
15" DVC2 & DVC4 ohm
closed 42.5 - 56.6 liter
ported 85 liter
which translates to
12"
sealed = 1 ft3 - 1.4 ft3
ported = 1.5 ft3 - 2 ft3
15"
sealed = 1.5 ft3 - 2 ft3
ported = 3ft 3
Does that even sound accurate to anybody?? To me those figures sound WAY too small and are smaller than even my smallest results from subwoofer enclosure calculators, however these are "Manufacturer recommendations" as per the forum.
