I would like to say I have searched everywhere for this answer and nothing has giving it to me. I have 2 of the same brand of subs just different models. The Specs on one sub is CS-GW1200 Type 11 13/16” (30 cm) Max. Power 1200W RMS Power 350W Sensitivity 87dB Frequency Response 23 - 2,000Hz Impedance 4Ω + 4Ω (Dual Input) Fs 25.4Hz Qts 0.315 Vas 3.42 ft3 Magnet Mass 53.7 oz Hole Cutout Diameter Dia. 11” (278 mm) Mounting Depth 5 1/2” (139.6 mm). The specs on the other sub is CS-AW6240 Type 12” (30 cm) Max. Power 1000W RMS Power 350W Sensitivity 87dB Frequency Response 25 - 2000Hz Impedance 4 Ω + 4Ω Fs 25.4Hz Qts 0.998 Vas 3.05 ft3 Magnet Mass 53.7 oz Hole Cutout Diameter Dia. 11 13/32” (289 mm) Mounting Depth 5 21/32” (143 mm). Would it work and how well if I hook them up together? Please no smart answers and explain your answer if you don't mind.
Mix matching subs is frowned upon. Definitely don't want them sharing airspace in a box. You may or may not be able to get away with running them in separate boxes but more likely than not results will be less than optimum.
