mcfalcon Posted November 19, 2014 Report Posted November 19, 2014 we dont do vs. But what I can tell you is that you will be happy with any of the three you mentioned. Still learning but have started gathering.
deadbroke Posted November 19, 2014 Author Report Posted November 19, 2014 Lol why does vs thread keep being mentioned im just asking if there would be enough space for those
deadbroke Posted November 19, 2014 Author Report Posted November 19, 2014 Those are the subs im referring to in a sealed 4th order in a blow through
Swordlordboy1234 Posted November 19, 2014 Report Posted November 19, 2014 Your using 3 brands in a vs thread. And only one of the 3 will be optimal in a 4th order based on TS specs. Can't say which publicly. Its best to do some research on enclosures and how TS specs relate to enclosure design. Good luck with the build. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
deadbroke Posted November 19, 2014 Author Report Posted November 19, 2014 Lol i give up. im not building a box. i dont know anything about it hence why im asking because the box designer gives a yes no then says cant do it box needs to be larger well is it the sub is it the designer? I pretty much have to figure out how to build a box for certain subs to know what fits just so i can tell someone to design a box? Id copy someone else if i knew box dimensions.
