sicrides6 Posted November 20, 2014 Report Posted November 20, 2014 Is it important to run ground runs from front battery to rear battery bank or is all grounds connecting directly to the frame significant enough to get the job done I've read opinions that go both ways. Just to get the typical ?s out of the way big three ran red top up front 4 kinetik hc2000 in back. Amps are 2 soundqubed 2200d all mechman 0ga ofc and mechman terminal ends. alt not upgraded yet but will be by christmas. Steve it would mean a lot to me if you through your 2cents in on this subject
YukonDCXL Posted November 20, 2014 Report Posted November 20, 2014 This has been tested many times and the voltage pretty much stayed the same doing it either way
zack_e89 Posted November 20, 2014 Report Posted November 20, 2014 Well I hope Steve has the time to chime in. I'm definitely not as smart and experienced as him, but from what I've read and done myself you will be fine with a good(sanded down, check with multimeter) ground to the frame in the rear. 97 Suburban 8 custom PSI Platform 3 18's
