High power handling Non PA highs
nocturnalrites101
You mean like component sets ???
Most good quality component sets can work with that much power and work well if installed correctly
I do not give brand recommendations.
You have a budget ??
^you have more options than you probably realize. Most decent components can probably take a lot more clean power than rated for. You are going to run into mechanical limits before thermal so if you can install well you won't have too much to worry about.
I have my tantric mids powered with 3x rms and they play like that all day long. Did the same with my prs 200watts to the mid from a component set rated for 50 watts.
Tweets you can burn up a bit easier so you need to be careful there. But again, if you cross your tweeters high enough it will be of less concern as well.
Team NorthWestSPL
wouldnt it also be the limitations of the crossovers?
id also prefer to stay away from focal . i did not like the way they sounded event he krx3s
  • Who's Online   0 Members, 0 Anonymous, 1469 Guests (See full list)
