Skax Posted November 25, 2014 Report Posted November 25, 2014 ok so I was trying to wire up my LEDs under dash this is the switch http://puu.sh/d4CqS/84b78aab13.jpg I have ground to ground and leds negative Supply volts to the led positive And ac on to radio constant Works fine when the switch is on but when switch is turned off sparks go to flying any ideas lol 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
reedal Posted November 25, 2014 Report Posted November 25, 2014 Try wiring to your HU's accessory wire or to a fuse that's only on when you key the ignition and see if it still does. Maybe your connections are touching? Did you use connectors? Or just wrap the wire onto it? SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Skax Posted November 25, 2014 Author Report Posted November 25, 2014 Try wiring to your HU's accessory wire or to a fuse that's only on when you key the ignition and see if it still does. Maybe your connections are touching? Did you use connectors? Or just wrap the wire onto it? Don't have a headunit in at the moment And yes I just wrapped it to see if I was getting it right by any chance should the leds positive go to acc on and radio constant to Supply volts ? 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
reedal Posted November 25, 2014 Report Posted November 25, 2014 Yeah I must have read the first post too fast and didn't catch that!! That's your issue. Supply is your 12v power, acc on means what you're trying to power. But I would suggest soldering your connections or getting some of these from a local Napa or hardware store http://m.lowes.com/pd/IDEAL-16-Count-Disconnects-Wire-Connectors/3363060 SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Skax Posted November 25, 2014 Author Report Posted November 25, 2014 Yeah I'm ganna run by Home Depot and grab some soon as I get of of school I figured that's what I did wrong lol thanks for the help bro 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
