gibblegeibel Posted December 7, 2014 Report Posted December 7, 2014 i helped out my aunt and uncle. by replacing there transmission on there 1999 dodge 1500 4wd. it has a 46re in the truck. before replacing the transmission the truck ran fine. now after replacing it has issues starting and when it does start it acts like it is searching for idle. but when you give it throttle it smooths out. i removed the crank sensor ring and torque convertor because my uncle wanted the remain seal replaced. but he changed his mine. so i installed it back the way i took off the crank sensor ring. then installed the torque convertor. i hooked everything up the way it was on the other transmission. i check the wires on the crank sensor since dodge mounted it on the back of the motor in the bell housing. it wires were not pinched, i hope it isn't that. but i am going up to look at it today and hope i can figure it out. i am going to see if it is getting spark. it is getting fuel. what do you guys think it could be?
deathcards Posted December 7, 2014 Report Posted December 7, 2014 what is is idling at? skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps
gibblegeibel Posted December 7, 2014 Author Report Posted December 7, 2014 the truck idles between 500 and 1000 rpms. it is not constant it over that range.
deathcards Posted December 7, 2014 Report Posted December 7, 2014 have you checked the IAC skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps
gibblegeibel Posted December 7, 2014 Author Report Posted December 7, 2014 no i have not but there was what looked like vaccuum lines under the trans that mounted to the cross member that i think could be backwards. so when i go up i am gana check for spark, the iac and to see if the vaccuum lines on backwards
gibblegeibel Posted December 8, 2014 Author Report Posted December 8, 2014 well it was the crank position sensor was broke off from the mount to the motor. so i replaced it and it work just like is should
