starting and running troubles. need help asap
i helped out my aunt and uncle. by replacing there transmission on there 1999 dodge 1500 4wd. it has a 46re in the truck. before replacing the transmission the truck ran fine. now after replacing it has issues starting and when it does start it acts like it is searching for idle. but when you give it throttle it smooths out. i removed the crank sensor ring and torque convertor because my uncle wanted the remain seal replaced. but he changed his mine.
so i installed it back the way i took off the crank sensor ring. then installed the torque convertor. i hooked everything up the way it was on the other transmission. i check the wires on the crank sensor since dodge mounted it on the back of the motor in the bell housing. it wires were not pinched, i hope it
isn't that. but i am going up to look at it today and hope i can figure it out. i am going to see if it is getting spark. it is getting fuel. what do you guys think it
could be?
  • Who's Online   0 Members, 0 Anonymous, 1247 Guests (See full list)
