bassmachine Posted November 26, 2006 Report Posted November 26, 2006 Does anyone know where I can cheap optima batteries or adassa or kinetic. Quote Windows Xp1 40 & 120gigHDDMSI BoardUNDERCONSTRUCTION Dr. Doom aka StarScream3kDestruction at ur service
Dale Posted November 26, 2006 Report Posted November 26, 2006 SonicElectronix >>> http://www.sonicelectronix.com/cat_i228_de...-batteries.html Quote
bassmachine Posted November 26, 2006 Author Report Posted November 26, 2006 would one red top do Quote Windows Xp1 40 & 120gigHDDMSI BoardUNDERCONSTRUCTION Dr. Doom aka StarScream3kDestruction at ur service
Dale Posted November 27, 2006 Report Posted November 27, 2006 would one red top do What exactly will you be using it for? Quote
mtxcivic07 Posted November 27, 2006 Report Posted November 27, 2006 i was talking to him earlier on another post.. im pretty sure he's going to be running 2 soundstream T4 12's and 2 1500d's... i would say do 2 or 3 red tops.. then get a big alternator if you havent already.. it will be needed.. the factory alt. wont be able to take 3000 watts. Quote 18's in a wall to come....Its not all about the posts....check the member #...
Dale Posted November 27, 2006 Report Posted November 27, 2006 I would recommend the yellow tops for the amps instead of the red tops. The red tops have bursts of power (Cranking amps), but the yellow tops are designed for prolonged high current draw (high AH ratings). Quote
Guest Brett32324 Posted November 27, 2006 Report Posted November 27, 2006 im about to be pushin all 4 of my 12"s. off of a 1500 rockford amp and a 2200 watt amp. think one red top will do. or should i get a yellow top. Quote
Dale Posted November 27, 2006 Report Posted November 27, 2006 im about to be pushin all 4 of my 12"s. off of a 1500 rockford amp and a 2200 watt amp. think one red top will do. or should i get a yellow top. I only recommend red tops for starting your vehicle. If you need a battery for your amps, I suggest you get a yellow top. Well in your case, it looks like 2 yellow tops might do you good :^ Quote
scratchy Posted November 27, 2006 Report Posted November 27, 2006 im about to be pushin all 4 of my 12"s. off of a 1500 rockford amp and a 2200 watt amp. think one red top will do. or should i get a yellow top. I only recommend red tops for starting your vehicle. If you need a battery for your amps, I suggest you get a yellow top. Well in your case, it looks like 2 yellow tops might do you good :^ I see your starting to turn into the regular old helper over here. Keep it up man :^ Quote then im rambo bitch
