Am i able to run a 4-channel and a monoblock off of a stock head unit? The car is a 2013 Ford Focus SE if that helps answer my question. What equipment would i need to buy for this? Thanks
2013 Ford Focus Hatchback SE
Kicker CS61234
Kicker 40CS674
Kicker KST25
Sundown Audio SA-12 D2
Rockford Fosgate t1000-1bdcp
Rockford Fosgate t400-4
Audio Control LC7i
Kinetik HC2000
0/1 Gauge
Big 3 Upgrade
Beer, babes, and bass.
What amps?
If you get line out converter or something like the JL cleansweep. It takes the headunit's speaker wires and converts them into RCAs.
Well there are going to be a few options.
Did you have a budget in mind?
What are the options?
Kicker CS61234
Kicker 40CS674
Kicker KST25
Audio Control LC7i
Kinetik HC2000
0/1 Gauge
Big 3 Upgrade
Yes you are.
Line out converters are cheap, will do the trick, but have significant cons.
A DSP like a 3sixty.3 will provide you with more configuration options but will cost a lot more, and is a lot more involved to set up.
Those are pretty much both ends of the spectrum of options.
I'm an RF guy, but there are other brands out there. This page will give you a good idea of all types of options though. http://www.rockfordfosgate.com/products/series/factory-integration
Yes you are.
What are the cons?
Kicker CS61234
Kicker 40CS674
Kicker KST25
Audio Control LC7i
Kinetik HC2000
0/1 Gauge
Big 3 Upgrade
Reliability and maintaining the quality of your signal being main ones.
are there any cheaper ones than the 3sixty.3?
Kicker CS61234
Kicker 40CS674
Kicker KST25
Audio Control LC7i
Kinetik HC2000
0/1 Gauge
Big 3 Upgrade
  • Who's Online   1 Member, 0 Anonymous, 680 Guests (See full list)
