conbon Posted December 12, 2014 Report Posted December 12, 2014 So i have six speakers in my car. 2 tweets, 2 front door and 2 rear door. Im getting a four channel to power them. If my knowledge is correct, i would have to wire a pair of speakers in parallel so would this work? -if i wire the front and back door speakers in parallel, i would get a 2 ohm load? and then the tweeters would just be at a 4 ohm load? and on the amp im powering the doors would be getting 120 rms to each speaker and then 80 rms to the tweets. Does this sound like it would be correct? 2013 Ford Focus Hatchback SE Kicker CS61234 Kicker 40CS674 Kicker KST25 Sundown Audio SA-12 D2 Rockford Fosgate t1000-1bdcp Rockford Fosgate t400-4 Audio Control LC7i Kinetik HC2000 0/1 Gauge Big 3 Upgrade Beer, babes, and bass.
Noel989 Posted December 12, 2014 Report Posted December 12, 2014 What amp are going to use? What's speakers are you going to use? Components? Do they come with crossovers? if not what what hu/processor are you going to use? Build Log - http://www.stevemead...-cruiser-el-pt/
SLYentist Posted December 13, 2014 Report Posted December 13, 2014 we need to know the nom. impedance of each speaker, and the RMS output vs impedance load for the amp you plan to use. Cables and wires almost never fail; the terminations do.
conbon Posted December 13, 2014 Author Report Posted December 13, 2014 we need to know the nom. impedance of each speaker, and the RMS output vs impedance load for the amp you plan to use. What amp are going to use? What's speakers are you going to use? Components? Do they come with crossovers? if not what what hu/processor are you going to use? Hifonics BRX640.4 Kicker KST25 (41KST254) Kicker 40CS674 Kicker 40CS654 Stock head unit in a 2013 Ford focus se and idk about LOCs yet idk what to get. 2013 Ford Focus Hatchback SE Kicker CS61234 Kicker 40CS674 Kicker KST25 Sundown Audio SA-12 D2 Rockford Fosgate t1000-1bdcp Rockford Fosgate t400-4 Audio Control LC7i Kinetik HC2000 0/1 Gauge Big 3 Upgrade Beer, babes, and bass.
SLYentist Posted December 13, 2014 Report Posted December 13, 2014 those speakers except the tweeters are all coaxials, they have tweeters built in. you can run one speaker per channel and get ~80w into 4ohms Cables and wires almost never fail; the terminations do.
conbon Posted December 14, 2014 Author Report Posted December 14, 2014 those speakers except the tweeters are all coaxials, they have tweeters built in. you can run one speaker per channel and get ~80w into 4ohms how do i do that off a four channel amp? 2013 Ford Focus Hatchback SE Kicker CS61234 Kicker 40CS674 Kicker KST25 Sundown Audio SA-12 D2 Rockford Fosgate t1000-1bdcp Rockford Fosgate t400-4 Audio Control LC7i Kinetik HC2000 0/1 Gauge Big 3 Upgrade Beer, babes, and bass.
islandpride684 Posted December 14, 2014 Report Posted December 14, 2014 those speakers except the tweeters are all coaxials, they have tweeters built in. you can run one speaker per channel and get ~80w into 4ohms how do i do that off a four channel amp? 1 speaker per channel...front speakers will be wired to ch 1 and 2 and rear speakers will be wired to ch 3 and 4...audiocontrol makes some good LOCs, budget friendly too... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
conbon Posted December 16, 2014 Author Report Posted December 16, 2014 those speakers except the tweeters are all coaxials, they have tweeters built in. you can run one speaker per channel and get ~80w into 4ohms how do i do that off a four channel amp? 1 speaker per channel...front speakers will be wired to ch 1 and 2 and rear speakers will be wired to ch 3 and 4...audiocontrol makes some good LOCs, budget friendly too... well what about the tweeters??? 2013 Ford Focus Hatchback SE Kicker CS61234 Kicker 40CS674 Kicker KST25 Sundown Audio SA-12 D2 Rockford Fosgate t1000-1bdcp Rockford Fosgate t400-4 Audio Control LC7i Kinetik HC2000 0/1 Gauge Big 3 Upgrade Beer, babes, and bass.
islandpride684 Posted December 16, 2014 Report Posted December 16, 2014 those speakers except the tweeters are all coaxials, they have tweeters built in. you can run one speaker per channel and get ~80w into 4ohms how do i do that off a four channel amp? 1 speaker per channel...front speakers will be wired to ch 1 and 2 and rear speakers will be wired to ch 3 and 4...audiocontrol makes some good LOCs, budget friendly too... well what about the tweeters??? run them off the head unit or ditch them... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
