wiring speakers
So i have six speakers in my car. 2 tweets, 2 front door and 2 rear door. Im getting a four channel to power them. If my knowledge is correct, i would have to wire a pair of speakers in parallel so would this work?
-if i wire the front and back door speakers in parallel, i would get a 2 ohm load? and then the tweeters would just be at a 4 ohm load? and on the amp im powering the doors would be getting 120 rms to each speaker and then 80 rms to the tweets. Does this sound like it would be correct?
2013 Ford Focus Hatchback SE
Kicker CS61234
Kicker 40CS674
Kicker KST25
Sundown Audio SA-12 D2
Rockford Fosgate t1000-1bdcp
Rockford Fosgate t400-4
Audio Control LC7i
Kinetik HC2000
0/1 Gauge
Big 3 Upgrade
Beer, babes, and bass.
we need to know the nom. impedance of each speaker, and the RMS output vs impedance load for the amp you plan to use.
What amp are going to use?
What's speakers are you going to use?
Components? Do they come with crossovers?
if not what what hu/processor are you going to use?
Hifonics BRX640.4
Kicker KST25 (41KST254)
Kicker 40CS674
Kicker 40CS654
Stock head unit in a 2013 Ford focus se and idk about LOCs yet idk what to get.
Kicker CS61234
Kicker 40CS674
Kicker KST25
Audio Control LC7i
Kinetik HC2000
0/1 Gauge
Big 3 Upgrade
those speakers except the tweeters are all coaxials, they have tweeters built in. you can run one speaker per channel and get ~80w into 4ohms
how do i do that off a four channel amp?
Kicker CS61234
Kicker 40CS674
Kicker KST25
Audio Control LC7i
Kinetik HC2000
0/1 Gauge
Big 3 Upgrade
1 speaker per channel...front speakers will be wired to ch 1 and 2 and rear speakers will be wired to ch 3 and 4...audiocontrol makes some good LOCs, budget friendly too...
well what about the tweeters???
Kicker CS61234
Kicker 40CS674
Kicker KST25
Audio Control LC7i
Kinetik HC2000
0/1 Gauge
Big 3 Upgrade
run them off the head unit or ditch them...
  • Who's Online   1 Member, 0 Anonymous, 1474 Guests (See full list)
